 Wanted: Someone that can help me out with my KA :(
shortyman4065
7 posters
shortyman4065
shortyman4065
Number of posts : 160
Vehicle : 95 240sx 91 240sx SE
Wanted: Someone that can help me out with my KA :( Empty
PostSubject: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 1:26 pm
I need help...my car won't even start anymore...it wants to, but won't. I don't have a ton of money and I don't really want to spend the little amount I have but if anyone can help me out that would be really appreciated. The check engine light is on had it scanned and had a couple of problems but nothing that would cause the engine to not start/die on me randomly. Not sure what it is...but if anybody knows and can fix it please let me know. Call/text me at 708-715-9289 or you can PM me. Please PLEASE help me out. I'll explain everythong on the phone. Thanks.
Number of posts : 969
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 1:53 pm
make sure theres gas = )
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 2:52 pm
lol there is...that's the problem it doens't even seem like it's getting any...we checked the fuel pump and it didn't seem like anything was wrong...but I'm just not sure. it sucks Sad lol but idk hopefully itll be fixed soon.
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 3:04 pm
new battery?
http://www.richiesrandoms.wordpress.com
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 3:49 pm
Nope...at first the car was running, I was sitting at a light, light turned green went 2 feet and completely died. Would not start at all it wanted to but wouldn't fire. The battery wouldn't be the cause of that especially when the car was running n it died. Also, even though I knew it wouldn't matter I had the car get jumped from some lady that pulled over and tryed to help...had the cables on for like 10 mis still didn't fire. After that me n my friend pushed the car off the road and had it sit for like 2-3 hrs tryed it again n it started. Drove it home brought it to mechanic had everything scanned wasnt sure said possibly a fuel pump but when we checked it seemed all good. Drove it home from mechanic which is like 3 mins from my house. Got to my house threw it in park car started reving by itself(slightly, not alot) turned it off...tryed to start it it wouldnt at all. Let it sit for the night tryed it this morning did same thing. Now it's just sitting and won't start at all...not sure of the problem.
Number of posts : 248
Vehicle : S13 Coupe
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 6:14 pm
the car can run, and still die because of the battery. Did you check the alternator? check your fuses as well.
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 6:26 pm
well still i had jumper cables going for 10mins+...i thought the akternator as well, but checked up to be fine. Ill check the fuses when i can
driftwithstyle07
Number of posts : 36
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 9:07 pm
check the amp fuse which is labeled in gray 75 ampres check , check and recheck the whole damn thing until i found the problem ............ i problem that i am having is that my car will crank but it will not fire due to a the injectors being clogged big time so once i change the fuel injector reprime the fuel line then it shoul start right up iam going to change my alternator so i know that i dont have any more electric problems but thats just me check ur fuel lines check everything trust me . is it a single slammer or a twin cam killer ? just asking
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 20th 2009, 11:55 pm
i had the injectors tested they were fine as well...altrenator was good..sparkplugs were fine... and its a dual cam i got a 95.
Number of posts : 322
Vehicle : '89 Piggy Coupe, '08 tC, '95 talon
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 21st 2009, 2:51 am
well this may be a long shot but disconnect the temp sensor in the intake manifold, then try to start it, or have someone try to start it and tap the fuel filter may be clogged?
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 21st 2009, 11:30 am
fuel filters extra clean, had my dad try that, ill try the temp sensor and let you no how that goes. Thanks everyone for your input.
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 21st 2009, 3:30 pm
Yeah try it, something like that happened to me, come to find out the temp sensor was bad ecu thought it was still cold even after the car was warmed up idle was bit high then it would die and couldn't start it, I talked to one of my friends so he disconnected it and it fired right up, he said it happened on both his 300zx, hope this helps, if not then check for spark
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 21st 2009, 5:12 pm
Yeah turns out it was temp sensor...just like you said had it replace. Got new spark plugs as well with an o2 sensor also replaced the rotor. Plugs and sensor were all carbonated, so basically they were shot lol. Had em all replaced n car started right up. check engine lights off now and had it scanned so hopefully nothing happens lol. everything seems to be alright now. Thanks a lot to everyone who helped me out, really appreciate it!
Number of posts : 192
Vehicle : my endless moneypit s13
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 22nd 2009, 3:54 pm
do you hear the fuel pump go on with the key in the on position? getting spark?
shortyman4065
shortyman4065
PostSubject: Re: Wanted: Someone that can help me out with my KA :(   Wanted: Someone that can help me out with my KA :( Icon_minitimeNovember 22nd 2009, 8:36 pm
It's all good now, check my post before yours ^^ Smile
» Wanted: 225/40-17 and 205/40-17
» Wanted: Z32 Ecu
» Wanted: 5spd S13 with KA
» wanted - 4 lug front hub for s13
» WANTED/NEEDED
