 Need some reeal nuts!
Number of posts : 3100
Need some reeal nuts! Empty
PostSubject: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 4:18 pm
No for real.
I need the four nuts that bolt the back of the differential, or diff cover, to the chassis. Also need driveshaft carrier nuts/bolts, the two bolts/nuts for the front struts/shock assembly (nearest to hub if I'm too confusing) and the nuts that go on the lower half of the header.
For s13 kade if that makes any difference. Need these asap. Don't tell me to go to a junkyard because that's wednesday's plan. Would be better if someone has them at hand that's the reason I made this thread.
Text me 773 316 5587
Thanks A ton.
Number of posts : 593
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 5:51 pm
Not telling you to go to a junk yard.....ACE Harware is your friend.
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 5:53 pm
Yea I go there tons too but they heave some cheap ass shit sometimes.
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 7:01 pm
and that's a bad thing?
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 8:11 pm
As in quality... Yea it's bad... I don't want my car to break down breaking more things in the process when I could have prevented it...
boostbaron
boostbaron
Number of posts : 109
Vehicle : s13
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 6th 2009, 11:15 pm
go to craigin industrial on the corner of grand and laramie...they have grade 8 nuts and bolts...half my car is put together with stuff from them
PostSubject: Re: Need some reeal nuts!   Need some reeal nuts! Icon_minitimeJuly 7th 2009, 12:17 am
Dude just get some grade 8 nuts and you should be set. Believe me.
» Fucking Nuts
» WTB 2 tension rod bolts and 2 nuts
» KICS Project R40 Lug Nuts Regular Gun Metal SINGLES
