| going crazy tryin to fix s13! | |
+5SIMON Nachtmensch SPEEDTRIBE Jay boostbaron 9 posters |
boostbaron Light Duty Poster
Number of posts : 109 Age : 36 Location : Chicago Vehicle : s13 Reputation : 1
| Subject: going crazy tryin to fix s13! May 21st 2009, 12:53 am | |
| ok guys this is whats up. I get out of work today and start my car and it runs fine till i get down the block and it starts shaking. It still ran ok just sounded like a subaru and was really slow. I figured it was a injector so i started unplugging them...I unplug no.1 cylinder injector and nothing changes...so i figure it has to be bad. I go home and put in a new injector and the car runs great and has power. I go out for a little cruise and i stop for a snack...when i go to start my car again the same sputtering and subaru sound i had before comes back. I unplug the new injector and nothing changes car still runs the same. i am thinking wtf. I also unplugged the spark plug wire from this cylinder and nothing changes, if i unplug other ones it does, the car also backfires like crazy now so now i am totally lost...any help here would be great btw car is a 91 s13 with a dual cam ka | |
Number of posts : 1432 Age : 85 Vehicle : S13 Garage Slut & S14 Daily Whore Reputation : 2
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 2:09 am | |
| you're not firing in cylinder 1. problem fixed. | |
SPEEDTRIBE Post Enthusiast
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 4:34 am | |
| it may be the spark plug not the injector. | |
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 8:28 am | |
| - SPEEDTRIBE wrote:
- it may be the spark plug not the injector.
SIMON Post Whore
Number of posts : 2058 Age : 33 Reputation : 0
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 9:23 am | |
| - Nachtmensch wrote:
i had the same problem on my SR, but it was a coilpack. change your plugs | |
240nut Forum Frequenter
Number of posts : 259 Age : 37 Location : Norridge, IL Vehicle : 1995 240sx Se Reputation : -3
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 9:28 am | |
| Also if the plugs are newer make sure your gap is right. Most spark plugs come pre-gapped but my brother and i have often found they are wrong. | |
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 9:45 am | |
| and if not the plugs, check your wires. swap wires between cylinders to see if the misfire changes cylinders, if the wires reach. otherwise just ohm them out to test them. | |
Adrian_S13 Wizard
Number of posts : 1310 Age : 35 Location : MP Vehicle : Aristo.... Reputation : 4
| Subject: Re: going crazy tryin to fix s13! May 21st 2009, 10:47 am | |
| Yeah I had that problem. Check plugs | |
zerepdivad Fucking Noob
Number of posts : 60 Age : 37 Reputation : -5
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 12:16 am | |
| Ok well you said when you replaced the injector it ran smooth for a while then started with the same problem. You more than likely didn't lube up the o-rings well enough when installing the injector and thus tore or damaged the o ring and now that injector is leaking. I had this issue before as well. You probably fouled out the plug in that cylinder but your injectors probably still fine just hit up autozone and get a new o-ring they have them in assortments behind the counter... lube the hell out of the o-ring before installing into the rail i used oil and it worked fine. | |
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 12:28 am | |
| i am gonna get a new injector tommrow...i work at a parts store so i have easy access to w/e i need...i just dont know what that is. | |
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 12:32 am | |
| you don't need a new injector i'm sure..... just get the o-ring.... you wokr at a parts store and don't know what an o-ring is? it's the rubber thing that is on the injector...... black ..... | |
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 12:37 am | |
| i know wtf a o-ring is, i just rather get a new injector/ its a free exchange, why would i spend extra money for an o-ring kit? | |
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 12:43 am | |
| hahaha don't get insulted... maybe because an o-ring is like what 25 cents is what i payed for mine. if even that. that way you can get a couple of them since apparently you aren't exactly pro at installing injectors hah. just messing around man | |
djexpo Forum Frequenter
Number of posts : 452 Age : 35 Location : Chicago Vehicle : 89 240sx Coupe Reputation : -1
| Subject: Re: going crazy tryin to fix s13! May 22nd 2009, 9:56 am | |
| yea so my injector or plug started acting up today. gotta find out which exactly. shit pisses me off. jake pm me ur number | |
| Subject: Re: going crazy tryin to fix s13! | |
