 Need help
dreimers
dreimers
Number of posts : 80
Vehicle : 95 240sx
Need help Empty
PostSubject: Need help   Need help Icon_minitimeMay 5th 2009, 11:18 am
I have problem with my ka24de. It is running extremely rich. I have tested all of the injectors. They all ohm out at 11-14 which is spec. I have also tested them for power. Again all have batt. voltage with the car running and in the run position. I have also checked for continuity of the wires, check the wires going to the injectors from the firewall. Also with the car running I can pull the #2 injector and it doesnt change, however when i pull the other 3 it runs worse. Same goes with pulling the plug wires. #2 no change other 3 change. I have checked the ECM for power to the injectors. All good. I have brand new spark plugs, injectors, pump and filter. I am thinking that it is the ECM a fault, but don't want to call it with out asking some one else. Any help would be greatly appreciated.
Number of posts : 593
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 7th 2009, 2:07 am
So lemme get this straight you tested all injectors and they within spec, but when you pull the plug on #2 injector wire to the spark, the idle doesn't change. Sounds like #2 is stuck in open mode. And with injector #2 stuck in open mode, all that fuel probably fouled the plug. You probably have to change the injector and spark out, had the same thing happen to me just before winter.
Number of posts : 1053
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 7th 2009, 8:25 am
yea i think its your injector is just stuck open
http://www.leagueltd.com
dreimers
dreimers
Vehicle : 95 240sx
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 7th 2009, 10:37 am
The injectors are new and the spark plugs are new. I will swap two of the injectors around and see if the problem moves, and I will let you know what happened. Thanks for the help.
dreimers
dreimers
Vehicle : 95 240sx
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 7th 2009, 4:34 pm
Swapped injectors and the problem moved. Went to Advance to get a new injector, put it in and so far so good. I need to put some more gas in my car. Thanks for the help guys. When I bought the car my friend said that he replaced all of the injectors, so I didnt even think about it being bad. Must have got a defective one out of the box. Again seems to be good now. Thanks again!!
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 7th 2009, 9:30 pm
alright good to hear man!!!
boostbaron
boostbaron
Number of posts : 109
Vehicle : s13
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 10th 2009, 12:01 pm
my 240 is running very rich too...ever since i got it. I have checked the injectors for power, unplugged them, ect. but the car is still pig rich, i can even smell it inside the car... I dont know if i should look into a MAF sensor or O2 sensor...you guys know these cars better than i do and any help is appreciated
dreimers
dreimers
Vehicle : 95 240sx
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 10th 2009, 10:50 pm
Is it in 1 cylinder or all of them? If it is in all of them, then I would say check the o2's and the MAF, FPR....ect. Something that could effect the entire system. If it is in just one of the cylinders then it could be a bad injector(Thats what happen to me), spark pug, wire, ect. You should have batt. voltage at the injector with it in run position, you should also have 11-14 ohms resistance per injector.
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 10th 2009, 11:56 pm
how do you know you are running rich?
a long time ago i thought the same thing.. i realized the o-ring on one of my injectors was ripped. so i was leaking gas. which made my car reek of gas
boostbaron
boostbaron
Vehicle : s13
Need help Empty
PostSubject: Re: Need help   Need help Icon_minitimeMay 11th 2009, 1:15 pm
If i let it idle for a couple minutes or move from a red light, a puff of black smoke comes out of the back and it smells like a rich a/f... its not oil for sure...and i will look into the ripped o-ring right now, because the car seriously smells like gas, its hard to drive
Need help Empty
Need help
