 low idle/bogs out at 4k rpm
Number of posts : 969
low idle/bogs out at 4k rpm Empty
PostSubject: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 7:43 am
once i turn on the car its runs great, but after it warms up and everything i start to get a low idle and also it starts to bog out once i hit 4k+ rpms, recently changed the spark plugs and wires. Went away for a little bit and then came back. Anyone have any suggestions on what i should check out?
Number of posts : 486
Vehicle : 97 240sx
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 11:06 am
Not sure, but if you cant figure it out take it
to Williams Service Center on Bartlett Rd. They are good mechanics and honest ones. Talk to Ed if you go, he knows his shit.
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 1:15 pm
Check ur MAF reading...with an OHM meter.
Number of posts : 355
Vehicle : 1991 240sx fastback sr20det part 2
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 7:40 pm
Little hard to help unless you let us know what your running.
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 7:42 pm
Its a stock KA.
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 8:03 pm
If its starts to bog down at 4000 rpms I suspect a fuel system problem. At lower rpms its initial torque and a modest amount of fuel but at higher rpms its the engine and fuel doing all the work. I had a similar problem with an 88 5.0
Check your fuel pump its filter check your fuel pressur with a gauge. This is stuff you can do without spending any real money besides the gasket for the pump re install.
PostSubject: Re: low idle/bogs out at 4k rpm   low idle/bogs out at 4k rpm Icon_minitimeApril 8th 2009, 8:42 pm
yeah someone told me it might be the maf.
Im going to check all this stuff out hopefully tomorrow. Thanks for the help
