 NVM
Project240
Number of posts : 311
Vehicle : 1991 Hatch (WTT 4 Coupe)
NVM Empty
PostSubject: NVM   NVM Icon_minitimeFebruary 23rd 2009, 3:11 am
NEVERMIND.
Last edited by Project240 on February 28th 2009, 11:37 am; edited 3 times in total
Number of posts : 3100
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 23rd 2009, 8:05 am
wernt you the same nigga that was selling all the kat shit cause you had lost your job? you need to sort out your priorities....
i wanna see where your "rebuild a Ka-T motor" is gonna end up...
good luck though.
Project240
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 23rd 2009, 11:18 pm
Appreciate it! And yep that was me, and now I have a job paying more with more hours, got almost everything paid off and have tax return money, sooo... yea, my priorities are pretty straight.
Thanks for lookin out though!
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 24th 2009, 7:16 am
Good shit. Just looking out homie. What are you plans as far as a rebuild?
Project240
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 26th 2009, 1:10 pm
I'm probably going to scratch the headers, my setups loud as it is and will probably use the cash on a E.C.V. instead, haha.
Well I had this planned for a while and already written up, it'll probably be some time before I can piece everything together again, I had a good amount of the parts already, but well you know already.
OEM Rebuilt Engine :
Head :
~ Decked
~ Hot Tanked
~ New Seals/Guides
~ 3 Angle Valve Job
~ JWT S1/Kelford Cams
~ Cleaned/Degreased/Painted (Light Grey)
Block:
~ Decked
~ New Seals
~ Hot Tanked
~ Shotpeened Rods
~ New Freeze Plugs
~ Bead Honed (OEM Bore)
~ Balance/Polish Rotating Assembly
~ ARP Head Studs
~ ARP Rod Bolts
~ Clevite Rod Bearings
~ Clevite Main Bearings
~ Cleaned/Degrease/Painted (Dark Grey)
Power House :
~ Garrett 50 Trim T3/T4 Turbo
~ JGS Top Mount Log Manifold
~ Tial 38mm Wastegate
Air Control/Intake :
~ 300zx Z32 N62 MAF
~ Apexi Power Intake Filter
~ Front Mount Intercooler w/ Custom 2.5" Piping
~ Greddy Type S BOV
Exhaust :
~ Greddy 3" Turbo Elbow or JGS DownPipe Kit
~ Megan Racing Stainless Sr20 Downpipe w/ Flex Section
~ Megan Racing Test Pipe**
~ BuddyClub Spec II Exhaust**
Fuel System :
~ DeatschWerks 740cc Injectors
~ Walbro 255lph Fuel Pump
~ Z32 Fuel Filter**
Oil System :
~ Stainless Steel Turbo Lines: -3an Feed, -10an Drain
~ NisSport Block Adapter w/ 3 1/8" Adapters
~ Pricing Oil Cooler Set-Up
Miscellaneous :
~ OEM Felpro Gasket Set
~ Remove ALL Emissions**
~ Remove Secondary Butterflys on Intake Manifold
~ Remove IACV, Crack Throttle Body
~ Remove Air Conditioning**
~ Remove Cruise Control**
~ Relocate Fuse Box to Glove Compartment, Wire Tuck & Relocate)
~ Optima Battery Relocated to Backseat
Electronics :
~ STRI DSD Oil Pressure Gauge
~ STRI DSD Oil Temperature Gauge
~ STRI DSD Voltometer Gauge
(All 60mm Smoked Lense White LED Backlight)
~ AEM Tru Boost, Boost Controller
~ AEM UEGO Wideband
~ Greddy Turbo Timer
~ DSD Gauges will be put into a custom gauge cluster that I plan to make & TruBoost & UEGO will be put in a separate cluster, I'm pretty syked to get those made, gunna look sick
TUNING :
~ NisTune Tunable ECU
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 26th 2009, 2:26 pm
all that jamm and you going with oem bottom end? why not buy after market? what are your power goals?
Project240
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 26th 2009, 10:51 pm
Its been discussed on Ka-T.org milleonz of times. If its not broken don't fix it basically. Theres Ka's running over 500whp on stock internals and barely a factory rebuild. Factory rebuild adds reliablility just as aftermarket bottom end really does. Shotpeened Rods are just as reliable as aftermarket, although pistons I'm still up in the air about at the moment, maybe maybe not.
One good point was if you end up blowing a rod later down the line and you bought pistons and rods, there goes a grand rolling down the street right there and then you have to rebuy them again, 2k. You ever seen an OEM rod that was blown out of a Ka block? It bends as they're supposed to do... Aftermarkets are to add strength and durability really, but it already has that, so its not really neccisary and is extra money that can pay for my cams and tuning....
(wrote in a rush)
Project240
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 26th 2009, 10:52 pm
Setup could easily make 350whp, which is my goal.
kpc_0721
Number of posts : 226
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 28th 2009, 6:11 am
I've blown a rod out the side of my KA on stock rods and arias pistons.
Managed to do it a couple blocks away from my house so I was able to roll it right up into my driveway haha
Project240
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 28th 2009, 11:35 am
Lol, lil engine that could. No matter the setup it could blow at any time, and if I'm runnin' what I'd like on OEM Rebuild, theres no sense on spending the extra money, or taking the extra risk of needing to spend more money.
NVM Empty
PostSubject: Re: NVM   NVM Icon_minitimeFebruary 28th 2009, 11:46 am
[quote="Project240"] No matter the setup it could blow at any time/quote]
eh scratch Paranoid Suspect
popcorn
NVM Empty
NVM
