 FS/FT: OBDII Greddy Intelligent Informeter - $290
jpcallmotor
6 posters
jpcallmotor
jpcallmotor
Number of posts : 59
Vehicle : Nissan Primera
FS/FT: OBDII Greddy Intelligent Informeter - $290 Empty
PostSubject: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 7th 2008, 5:50 pm
I have for sale a brand new Greddy Intelligent Infometer (Blcak color). This is a really neat tool that is completely plug and play, no splicing at all. Great for datalogging and is really easy to use. The Greddy Intelligent Informeter is a inexpensive solution to monitor your your veichles parameters via the factory OBDII Port. This will allow you to read up to 25 pieces of information.
Features:
-Communicates with the factory ECU to read up to 25 Channels Like: Speedometer, RPM, Water Temp, Ignition Timing, Injector Rate, Intake Air Temp, Fuel Temp, Air Flow Voltage, Intake Manifold Press, 02 Sensor Voltage, A/F, Battery Voltage, Throttle Position, WGV, ATF Temp, EGR Temp, Gear Position, 4WD Ratio, Exhaust Temp.
-Along with being useful it is also stylish. The face plate can be changed to different colors to match your interior as well as the display background.
-For use with veichles which use OBD2 Ports, also can plug into a cigarette lighter plug that powers up the unit.
-Features a easy to read Color LCD Screen, Monitor Record and Playback, and 180 Degree Monitor Flexibility.
This unit will work with all Japanese OBDII vehicle manufactures listed:
Nissan(OBD1 and II), Toyota, Honda/Acura, Mitsubishi, Subaru, Daihatsu... You can test before you buy.
I opened it to test it on my car, but it will not read on my ECU. (I don't have a 240SX) So If you are interested, email me and I promise we can hook it up before you buy to confirm it is compatible with your vehicle. Hooking it up to test takes literally a minute, its just like testing for OBDII CEL codes via the same port under your dash.
I am looking for $290 or trade for... I paid over $350 shipped for this so i am taking a loss because it doesn't work on my car. Email me or PM jpcallmotorATyahooDOTcom if you want to check it out, I am located on the southside by 87th Kedzie and it would be no problem to meet up.
FS/FT: OBDII Greddy Intelligent Informeter - $290 0704_impp_09z+honda_s2000+gauge
FS/FT: OBDII Greddy Intelligent Informeter - $290 448_greddy
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 8th 2008, 12:01 am
any settings that it can change?
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 8th 2008, 12:09 am
No, its simply a monitoring device.
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 8th 2008, 12:10 am
oh ok. thanks anyway
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 11th 2008, 4:51 pm
bump...
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeNovember 17th 2008, 11:18 pm
Sleep
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 2nd 2008, 9:03 pm
Bump...
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 9th 2008, 10:54 pm
Here is my quick install demo on a 96' Infiniti G20. Its really easy to hook up!
*NOTE: Installation might vary due to diagnostic port locations, depending on make and model.
1.) Take off fuse panel and locate your diagnostic tool port.
FS/FT: OBDII Greddy Intelligent Informeter - $290 011-9
2.) Then plug the connector into the port supplied with the infometer.
FS/FT: OBDII Greddy Intelligent Informeter - $290 012-10
FS/FT: OBDII Greddy Intelligent Informeter - $290 013-9
3.) Once everything is plugged in, turn the car on and the infometer will power up.
FS/FT: OBDII Greddy Intelligent Informeter - $290 014-12
FS/FT: OBDII Greddy Intelligent Informeter - $290 016-9
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 15th 2008, 8:50 pm
Up... Make me an offer.
Number of posts : 1053
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 15th 2008, 9:10 pm
sorry ill just give you a bump
i dont need it, but it looks cool
http://www.leagueltd.com
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 15th 2008, 11:35 pm
Thats Consult port. OBD2 looks different.
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 16th 2008, 10:16 pm
Thanks for the bump.
And yea, thanks for pointing that out, that is the consult port. The OBDII port is located below my glovebox. But either way it does work in the above shown port.
The unit comes with 2 connectors .
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeDecember 21st 2008, 2:17 pm
Jerk attention beer
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeJanuary 7th 2009, 9:25 pm
bump
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeJanuary 16th 2009, 2:53 pm
Back up on top.
$250 THIS WEEKEND?
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeJanuary 29th 2009, 10:10 pm
bump 1...
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 1st 2009, 5:06 pm
bump 2....
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 1st 2009, 5:56 pm
bump it again
i dare you
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 7th 2009, 1:26 pm
$200 picked up!
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 7th 2009, 7:57 pm
face it, no one wants it.
put it on ebay
jpcallmotor
jpcallmotor
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 8th 2009, 5:03 pm
Yea, I pretty much beat this topic to death.
I never listed on ebay, I might try that out then, I have seen a few on there. Thanks for the advice.
It will york in your MR2 BTW...^^^
Number of posts : 1608
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 8th 2009, 5:33 pm
Though quite useless.
PostSubject: Re: FS/FT: OBDII Greddy Intelligent Informeter - $290   FS/FT: OBDII Greddy Intelligent Informeter - $290 Icon_minitimeFebruary 8th 2009, 5:41 pm
i know it works, i have no need for it.
ebay is pretty simple. i've listed only a few things, one being my old motor. real easy thumb up
» OBDII tuned ECU by JWT
» WTB obdII manual ecu
» wtb greddy bov
» WTB: Greddy BOV
» FS: greddy e-manage with all the goodies
