| What's so great about coilovers? | |
+18ilia Dorifuto-zoku dwvinny RAD MIKE Circa 3006 Adrian_S13 D*S Roski jdmwackness D*S Dstar Specter jh3xp koukimonster Nachtmensch Jay SPEEDTRIBE Dirty Dee hs13kls FusionR300zx nephthys 22 posters |
Adrian_S13 Wizard
| Subject: Re: What's so great about coilovers? July 13th 2008, 1:46 pm | |
| Had that problem with my old s13 in winter it was my slave! | |
SPEEDTRIBE Post Enthusiast
| Subject: Re: What's so great about coilovers? July 13th 2008, 3:15 pm | |
| check to see if there is any fluid in the master cylinder, if no then it was your slave cylinder, 2 bolts and a threaded line, takes about 15 minutes to change and bleed. like D*star said, 17$
nephthys Fucking Noob
Number of posts : 94 Age : 47 Location : nw suburbs Vehicle : 91 red 240sx se Reputation : 0
| Subject: Re: What's so great about coilovers? July 13th 2008, 10:33 pm | |
| We replaced the slave cylinder which apparently was leaking and bled it multiple times. Not resolved though so I believe we're going to replace the master cylinder next. | |
| Subject: Re: What's so great about coilovers? July 13th 2008, 11:31 pm | |
| - nephthys wrote:
- We replaced the slave cylinder which apparently was leaking and bled it multiple times. Not resolved though so I believe we're going to replace the master cylinder next.
hope you get your small problem solved | |
| Subject: Re: What's so great about coilovers? July 14th 2008, 5:35 pm | |
| Subject: Re: What's so great about coilovers? July 15th 2008, 10:59 am | |
if you have stock loop - your clutch is going to be a bitch to bleed. I bet that you still didn't get all the air out. | |
| Subject: Re: What's so great about coilovers? July 15th 2008, 4:45 pm | |
| easy to bleed, my dad took apart the master and cleaned it but he's getting a rebuild kit now. which apparently is hard to find, but he found one. not sure why he didn't just have us get a new one. so master is being rebuilt and put back tomorrow. | |
| Subject: Re: What's so great about coilovers? July 16th 2008, 2:06 pm | |
| piston seals and clutch valve, that was the problem. | |
| Subject: Re: What's so great about coilovers? July 18th 2008, 3:12 pm | |
| Subject: Re: What's so great about coilovers? July 19th 2008, 12:06 am | |
| myspace default right there | |
| Subject: Re: What's so great about coilovers? July 19th 2008, 1:19 am | |
dwvinny Light Duty Poster
Number of posts : 116 Age : 46 Reputation : 0
| Subject: Re: What's so great about coilovers? July 19th 2008, 10:29 am | |
| theres a 99.99999999 percent chance you popped a spring on the clutch disk and its now lodged between the disk and pressure plate if you need help fixing it lemme know ill do it cheap | |
Dorifuto-zoku Fucking Noob
Number of posts : 1 Age : 34 Reputation : 0
| Subject: Re: What's so great about coilovers? July 19th 2008, 7:03 pm | |
| i actually have Stance GR+ Pro on my fastback and i love them, in my opinion they are great if you like to hang some turns or the occasional drift, but if you just essentially want a decent daily then just find some decent struts and springs for cheap but if you get the coil overs you will not be disappointed | |
ilia Light Duty Poster
Number of posts : 107 Age : 38 Reputation : 6
| Subject: Re: What's so great about coilovers? July 21st 2008, 4:51 pm | |
| I never post here, and I didn't read anything anyone wrote, but coilovers are cool because you can lower your car a whole lot without completely and totally handling like shit.
A standard damper is typically not designed to work at any ride height that anyone would consider "cool" and so handles like poo when lowered to the correct height. The cost to buy a damper that is designed to work in that range of travel is high enough to justify a coilover purchase.
If you're at a really good looking height, your car will still handle like shit, but less so with coilovers than just with shocks and springs. | |
| Subject: Re: What's so great about coilovers? July 21st 2008, 5:13 pm | |
| - ilia wrote:
- A standard damper is typically not designed to work at any ride height that anyone would consider "cool" and so handles like poo when lowered to the correct height.
actually you're wrong. Although you got the right idea. damper is designed for suspension travel (ie 5in of travel) you can move it up and down all you want. what makes it "cool" or 4x4 ride height, is the mounting. Since most coilovers out there change the ride height independent of shock travel, as well as give you option to put some preload/slack on your springs. That dual adjustability allows you to have "cool" ride height. Most of the dampers themselves are garbage, thats why people say it won't handle well, etc. Look up Wiisass's posts about suspension tuning. | |
| Subject: Re: What's so great about coilovers? July 21st 2008, 5:58 pm | |
| - dwvinny wrote:
- theres a 99.99999999 percent chance you popped a spring on the clutch disk and its now lodged between the disk and pressure plate if you need help fixing it lemme know ill do it cheap
On what basis did you make that decision? At what point did you decide that was more probable than a slave cylinder that she/he didnt bleed correctly after install due to damper box still being there? And what the fuck is all this suspension Geometry talk? Did i hit the wrong button and end up on Scirroco forum? | |
| Subject: Re: What's so great about coilovers? July 21st 2008, 6:12 pm | |
| - Jay wrote:
actually you're wrong. Although you got the right idea. Haha ok guy. | |
| Subject: Re: What's so great about coilovers? July 21st 2008, 6:14 pm | |
| ILIA BUILDS OPEN WHEEL RACECARS IN ARIZONA.
THIS SHIT IS NOT A GAME. | |
| Subject: Re: What's so great about coilovers? July 21st 2008, 6:22 pm | |
| Real talk!
Hahaha
Drifting is serious! | |
REVGASM Light Duty Poster
Number of posts : 143 Reputation : 0
| Subject: Re: What's so great about coilovers? July 21st 2008, 8:47 pm | |
| - D*star wrote:
And what the fuck is all this suspension Geometry talk? Did i hit the wrong button and end up on Scirroco forum? nigga said scirroco....now that shit is serious talk | |
| Subject: Re: What's so great about coilovers? July 22nd 2008, 2:31 am | |
| Yeah, you're right. "drifting isn't serious" gives you a right to just spew BS all around and confuse little kids. My bad. | |
| Subject: Re: What's so great about coilovers? July 22nd 2008, 4:11 am | |
| you guys have no idea how to set up suspension, heres a quick lesson in geometry. take notes 1)dump it as far as you can go without dragging aero and still being able to turn, 2)put as much camber in as it takes to fit your wheels inside the fenders. 3)be awesome. if you guys need anymore advice on suspension tuning just PM me | |
| Subject: Re: What's so great about coilovers? July 22nd 2008, 9:26 am | |
| or you can dump it and later correct the angles of the suspension you just fucked up.
doesnt take much. RCA's, some aftermarket tie rod ends have a spacer thing to compensate for lowered cars, etc. it will allow a more full range of suspension (control arm and tie rod arcs and such)
anyway... | |
| Subject: Re: What's so great about coilovers? July 23rd 2008, 5:30 pm | |
| - Rowdys2000 wrote:
- D*star wrote:
And what the fuck is all this suspension Geometry talk? Did i hit the wrong button and end up on Scirroco forum? nigga said scirroco....now that shit is serious talk Seriously. | |
007 Light Duty Poster
Number of posts : 182 Age : 93 Location : Chicago Vehicle : RB26 S14 Reputation : 0
| Subject: Re: What's so great about coilovers? July 23rd 2008, 11:22 pm | |
| the only reason to buy coilovers is so you can adjust ride height | |
| Subject: Re: What's so great about coilovers? | |
