Chicago Area 240sx Since 2006. |
| SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. | |
| | Author | Message |
PacoX Light Duty Poster
Number of posts : 123 Age : 40 Reputation : 0
| Subject: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. July 7th 2008, 3:55 pm | |
| If you want (more) pics of anything, let me know and I'll try to take some. I'd prefer if you contact me via email- rrozyck@gmail.com, as I check that many times a day, unlike car forums. Most of this stuff is located close to the loop, so if you're somewhat close we could arrange pickup. TurboFab mani/dp/dumptube: Top mount log manifold for SR20DET, comes with dumptube and downpipe. Wastegate flange is Tial 38mm pattern; downpipe has had the 5 bolt flange chopped off and a 4 bolt GT style flange welded on. The guy I got this from was putting the SR in a Frontier, so the downpipe probably won't fit an S chassis. It looks just like the pics I found online of the DP though, other than the different flange, so the fitment should at least be close, and not require much more than a chop and reweld to get right. $230 Energy Susp. rear poly bushing kit: For S14, will do rear uprights and control arms as well as LCAs, red, new, $45 Saga electronic boost gauge: 60mm Saga 2.0 Series (warning function, but no recording). Reads in PSI, amber lighting, stepper motor design, used but in nice shape, comes with stand. $75 G-Force bolt ends: Have 6 3" ones ( http://www.gforce.com/products/harness/103W.php), and 2 2" ones ( http://www.gforce.com/products/harness/103H.php), new, $2.50 each Canton Mecca oil filter: 6" remote mount filter that filters down to 8 microns, comes with 2 -10 AN to -12 AN o-r adapter fittings (so you can use -10 AN hoses with this). Has 2 1/8" NPT holes drilled and tapped into the housing, can use for pressure sensors/feeds, or just plug. Also has another small hole drilled and tapped into housing, perhaps M6x1.25? I'm thinking the last guy used this to mount it...I was just going to plug it. $40 T25 compressor discharge elbow: $15 S13 SR clutch & flywheel: $20 each
| | | D*S Trucky DS! DS! DS!
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. July 7th 2008, 9:29 pm | |
| Do both hardlines come with the screws on booth ends? | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. July 9th 2008, 11:24 am | |
| No, I might have one or two of the screws, but I'm pretty sure I'm missing some of them. When I bought this motor it didn't come with a turbo, and most of the accessories were in a big plastic box, so I'd have to dig around there. | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. August 27th 2008, 12:14 pm | |
| Stuff is still available, bumpity. Make me offers! | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. August 27th 2008, 4:50 pm | |
| Might take that boost gauge of ur hands...... | |
| | | D*S Dstar *********
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. August 27th 2008, 5:15 pm | |
| What do you need a boost gauge for Trucky? Tell us. Please. Enlighten us. | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. August 28th 2008, 9:31 am | |
| Yea man, let me know. It's a nice gauge, I just want to run 52mm this time so I'm getting rid of my 60s. | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. August 28th 2008, 7:47 pm | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. September 23rd 2008, 3:23 pm | |
| Still have everything. Make offers! | |
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. December 30th 2008, 5:25 pm | |
| Everything still FS, open to offers. | |
| | | Sponsored content
| Subject: Re: SR T3 log, S14 rear poly bushings, Saga boost gauge, SR AC.. | |
Similar topics | |
| Permissions in this forum: | You cannot reply to topics in this forum
