just about everything you will need to do a manual swap, MINUS the clutch pedal, and clutch.
will include flywheel, pressure plate if you want it ( i would get a new one judging by the look of this clutch and the fact that the car wouldnt drive it was owned by a horrible driver) master and slave cylinders, fluid lines for them, the trans itslf obviously, stock shift knob, and bellhousing bolts.
looking for $200 picked up, will deliver for gas money
I am in bartlett, il right near Elgin area.
also parting out a blue interior minus the dash and door panels of a 1990 s13 hatch
motor runs KA24e (single cam) made some what of a rotational knocking noise. previous owner thought it was a bent valve, me and my dad think it has something to do with the burnt to sh*t clutch put back on the flywheel wrong.
so engine $100 pick up only, ( i do have an engine hoist if you bring a truck i will lift it on there for you.)
