| My car is dead :( | |
+4LigouriRd. Nackers Specter Atown 240 8 posters |
| Subject: My car is dead :( October 10th 2006, 11:38 pm | |
| So decided to check compression today and only had it in 1 cylinder. No spark Not running I dont know wat to do | |
| Subject: Re: My car is dead :( October 10th 2006, 11:52 pm | |
| new engine simple as that | |
| Subject: Re: My car is dead :( October 11th 2006, 12:53 am | |
| BHG?
Dizzy took a shit?
SR swap? | |
| Subject: Re: My car is dead :( October 11th 2006, 1:00 am | |
| alot of peolpe say since it's more then 1 cylinder w/ no compression, that the arp studs may have came loose. I'm hoping that that is all it is | |
LigouriRd. Light Duty Poster
Number of posts : 183 Age : 45 Location : Chicago, South burbs Vehicle : Zenki S14/Chuki S13 Reputation : 0
| Subject: Re: My car is dead :( October 11th 2006, 7:25 am | |
| - Quote :
- alot of peolpe say since it's more then 1 cylinder w/ no compression, that the arp studs may have came loose. I'm hoping that that is all it is Sad
-I hoping that is the case as well. The only other reason that you would loose compression is if the valves aren't sealing or you skipped a tooth on the timing chain (highly unlikely). Of course the valves not sealing would not just suddenly happen it would be gradual. The head bolts could do that, seal fine when hot then loosen as the engine cools(aluminum contract a lot when it cools). It's not like your rings are all of a sudden not going to seal. How do you all of a sudden have no spark? It obvious it not starting, but if you take the spark plugs out is there litterally no spark across the plug? As for the rest of you nay sayers (new engine...SR swap?), huuush! | |
| Subject: Re: My car is dead :( October 11th 2006, 12:16 pm | |
| - LigouriRd. wrote:
- Quote :
As for the rest of you nay sayers (new engine...SR swap?), huuush! I have known that my valve stems were going bad because before i rebuilt, i was blowing smoke. After i rebuilt, i was still blowing smoke. The valve seals are the only thing i didn't replace. There is no spark at all across any plug, unless i'm just being retarded but i've tried grounding it and nothing. All 4 plugs going bad doesn't seem plausable. Also, i had my stock oil p. sender unplugged for 1 day, and when i plugged it in yesterday the oil light came on. The day before this happened i changed my oil. | |
| Subject: Re: My car is dead :( October 11th 2006, 5:24 pm | |
| as funny as this sounds... check the coils ground
seriously that's what happened to me once | |
| Subject: Re: My car is dead :( October 11th 2006, 10:43 pm | |
| which coil ground? I cant seem to find any other then the one that plugs into the side. | |
| Subject: Re: My car is dead :( October 12th 2006, 12:08 am | |
| - Specter wrote:
- as funny as this sounds... check the coils ground
seriously that's what happened to me once and how will that prevent him from having compression?? you, DID torque everything, and i mean EVERYTHING, to spec right? | |
| Subject: Re: My car is dead :( October 12th 2006, 7:51 am | |
| - Quote :
- Also, i had my stock oil p. sender unplugged for 1 day, and when i plugged it in yesterday the oil light came on.
-sheet son! Well, before you start the car again, pull the fuel pump fuse and crank the motor over until that light goes out. If it doesn't you may have bigger problems. | |
| Subject: Re: My car is dead :( October 12th 2006, 9:49 am | |
| Subject: Re: My car is dead :( October 12th 2006, 3:24 pm | |
| Joe I think you should just come to the conclusion that your ka has no potential | |
Jesse Graduated Hipster
Number of posts : 611 Age : 60 Reputation : 4
| Subject: Re: My car is dead :( October 12th 2006, 3:52 pm | |
| Subject: Re: My car is dead :( October 12th 2006, 5:31 pm | |
| haha my friend keeps saying to kick it lol.
Lester shut up. U just dont want my engine ot be better then ur's lol. Where have u been latly i havn't talked ot u in a while | |
| Subject: Re: My car is dead :( October 12th 2006, 6:58 pm | |
| I dont know Ive just been cruisin the town in my working sr is all. So why dont you sell it and get an sr or why doesnt your rich as swing for an rb | |
| Subject: Re: My car is dead :( October 12th 2006, 10:20 pm | |
| because, i've put to much into the KA lol.. I'm determined KA-T Mother Fucker | |
| Subject: Re: My car is dead :( October 14th 2006, 2:04 am | |
| hahah thats some determination just fucking pull the motor untill the meet and seeing as everyone is using ur crib have them help you put it in the CORRECT way | |
25psi_SeR Fucking Noob
Number of posts : 50 Age : 36 Reputation : 0
| Subject: Re: My car is dead :( November 1st 2006, 1:07 am | |
| did you solve the problem? i would think it has something to do with your rebuild because its unlikely for that many valves to go bad to cause the compression to be 0 in all 3 cylinders. Or even 3 piston rings going out at once is pretty rare also.
I would think its something with the headgasket, or you fucked up rebuilding. | |
| Subject: Re: My car is dead :( November 1st 2006, 11:06 pm | |
| havn't solved the problem yet.
Timing was off 1 tooth ahead on each cam, guide was MIA on the top of the head.
Gotta drop the pan see if i can find a bolt and guide lol | |
| Subject: Re: My car is dead :( November 1st 2006, 11:13 pm | |
| HA HAAAA
you're screwed, have fun with the pan man [it sucks] | |
| Subject: Re: My car is dead :( | |
