Number of posts : 1053 Age : 35 Location : champaign,il Vehicle : 1991 black coupe Reputation : 4
| Subject: somthing acting up February 19th 2008, 10:27 am | |
| okay so i was driving one day and my car starts to sputter.. and i look under the hood and try to figure it out..didnt, i got home pulled it into the garage.. and i smelt somethign rank. so 1. my cat is clogged (maybe thats it)- i orderd a test pipe. 2. i replaced all my plugs and wires and it fixed it...for a while 3. i noticed the distributor cap was corroded(i replaced it) fixed it for a while.. and now its doing it again. 4. i pulled each plug one at a time. and obviously it bogs down when i pull them.. except for the 3rd plug..so id guess maybe the 3rd plug is bad.
AND for some reason my dash lights dont work, if i turn on my head lights. and something sparked in the back of my guage cluster like 3 weeks ago, and since then the lights dont work. and i cant switch my blend door. (stays only at defrost and feet, cant go to anything else) | |
Number of posts : 355 Age : 113 Location : North Riverside under the mall Vehicle : 1991 240sx fastback sr20det part 2 Reputation : 12
| Subject: Re: somthing acting up February 25th 2008, 9:27 pm | |
| You could have a lose wire grounding somewhere and baking. | |
| Subject: Re: somthing acting up February 26th 2008, 9:47 am | |
| hmm...well i dont know i havent gone into tooo much detail in checking it, so i just havent been driving it all too much.
but thanks for your help. | |
Guest Guest
| Subject: Re: somthing acting up March 5th 2008, 7:57 pm | |
| Subject: Re: somthing acting up March 5th 2008, 8:14 pm | |
| we tried fixing the cluster lighting today, but I guessed wrong as to what was causing the problem. | |
Guest Guest
| Subject: Re: somthing acting up March 5th 2008, 11:53 pm | |
| did you try the distributor itself? rotor? |
| Subject: Re: somthing acting up March 6th 2008, 8:12 am | |
| no..but i know its not the distributor.still been messin with it..i think its the MAF..becasue the car is fun unless its super duper cold | |
Guest Guest
| Subject: Re: somthing acting up March 6th 2008, 11:17 pm | |
| I had the same problem I just fixed it today. Cylinder 2 was not firing.
I changed
Distributor Cap Rotor Plugs Spark plug
Timed it all over and bam sparking on all cylinders, still cuts of at high rpm. It might be the Maf Ill probaly changed that tomorrow. |
| Subject: Re: somthing acting up March 6th 2008, 11:23 pm | |
| hmm...i dont know how to do timing...but.. my car hasnt been acting up...but if does..ill def just have to change all of that
hey thanks a lot man | |
| Subject: Re: somthing acting up | |
