 Dirty Dee's Build
Go to page : Previous  1 ... 9 ... 14, 15, 16, 17, 18  Next
PostSubject: Re: Dirty Dee's Build   May 31st 2010, 11:41 pm
looking good!
PostSubject: Re: Dirty Dee's Build   June 1st 2010, 12:13 am
DAAAAAYUM
cleanest looking swap I've seen in a minute.
PostSubject: Re: Dirty Dee's Build   June 5th 2010, 11:41 pm
small update. Got the driveshaft connected. Had an issue with it at first since the motor mounts had a forward preload
jacked up the front end and loosed all bolts and was able to get everything lined up and connected properly:
Tried test fitting a japspeed downpipe/turbo elbow, but there was no way it was going to fit with the steering column. mad A waste of money and now I have to get a custom turbo elbow made.
The Mishimoto radiator is slightly warped so it doest fit right. Should I return it for a new one, or would I be able to twist it into shape without compromising it?
Started to work on the wiring harness. I need to go through all of it cause some spots seem pretty sketchy
Need a bit more pull for the new tires
PostSubject: Re: Dirty Dee's Build   June 6th 2010, 12:32 am
Dirty Dee wrote:
why would they not just de-pin that? tard
PostSubject: Re: Dirty Dee's Build   June 6th 2010, 12:38 am
because whoever did that could only count to potato
PostSubject: Re: Dirty Dee's Build   June 15th 2010, 10:38 pm
got my car back from ILL Garage today. I had to get my turbo elbow/downpipe modified so it would clear the steering column.
Got the cat deleted and it goes straight into the exhaust nod/hump
PostSubject: Re: Dirty Dee's Build   June 15th 2010, 11:03 pm
damn, I never got to see the finished result. I did snap a pic of the bay while it was there on Saturday Razz
PostSubject: Re: Dirty Dee's Build   June 16th 2010, 10:27 pm
pics of the downpipe
workin on the wiring harness. Removing old cracked tape and re-taping it, tagging all plugs, and finding any trouble spots that need fixing.
I need to find a place that sells twisted shielded pair wires and also just single shielded wires for some of the plugs that got extended.
PostSubject: Re: Dirty Dee's Build   June 16th 2010, 11:22 pm
Looking good. Smile Mind if I grab those pics and rehost to show off our work?
PostSubject: Re: Dirty Dee's Build   June 16th 2010, 11:24 pm
sure. I can take better photos this weekend though if you want
PostSubject: Re: Dirty Dee's Build   June 16th 2010, 11:26 pm
doesn't matter
get it running instead Smile
PostSubject: Re: Dirty Dee's Build   July 9th 2010, 11:37 pm
I seemed to have jinxed myself when i set my May deadline to get the car running. I barely have the weekends to myself anymore to work on the car. Jerk
But anyway, I have been making some progress during the weeks on the wiring harness. Several sections required for the shielding to be extended, so I made my own shielding using the exterior section of coaxial cable.
I used a utility knife and scored the exterior sheathing just enough so that a tug was only needed to remove it. I had to make sure not to press down too hard otherwise I would have cut through the copper braiding
After getting it all exposed, I squeezed one section down to get the dielectric section into a vise. The braided copper acts like a chinese finger trap, so you have to compress it to get it off
Where the original shielding needs to be extended
I then stretched it all so it was snug on the wire and began to cut the excess that was scrunching up at the plug
Engine side of the wiring is basically done. All i need now is to clean up the ECU side of it
PostSubject: Re: Dirty Dee's Build   July 10th 2010, 2:35 am
cool race car, bro.
you got a fire extinguisher yet? If you dont, make sure to get the CHROME model, it will look much better on white.
PostSubject: Re: Dirty Dee's Build   July 10th 2010, 12:13 pm
For sure
Also need to get a flame retardant suit too
PostSubject: Re: Dirty Dee's Build   July 10th 2010, 2:34 pm
I'm never gonna hear the end of this haha.
It has come a long way from the night you first got home the RB20.
PostSubject: Re: Dirty Dee's Build   July 10th 2010, 2:36 pm
Dirty Dee wrote:
For sure
3 layer NOMEX.
PostSubject: Re: Dirty Dee's Build   July 11th 2010, 2:55 am
DS LongGrain wrote:
Dirty Dee wrote:
For sure
3 layer NOMEX.
nomex underwear and head sock.
PostSubject: Re: Dirty Dee's Build   August 8th 2010, 2:24 am
is this done yet? update me.
PostSubject: Re: Dirty Dee's Build   August 8th 2010, 6:46 am
He sold the car and left for California to marry his boyfriend.
PostSubject: Re: Dirty Dee's Build   August 8th 2010, 12:42 pm
I've been out of the state for a chunk of july so I didnt do much with the car.
got back from cali late last week, so now I'm back to working on it
I hooked up the coolant lines going to the turbo. A water hardine was missing so I had to find a brass tee that was small enough to fit in the limited space between the motor and the firewall.
I wired up the consult plug, and I cut holes for the intercooler piping. I used some of the plastic jacketing that was left over from the coaxial cables I stripped to use as a trim for the intercooler holes so that I wouldnt cut my hands or scratch anything up. Its pressed on, but I'm going to use some silicone to glue it to the hole.
I need to swing by to TF tomorrow with my warped radiator. It took some time to get some response due to Mishimoto, but they said they need to ship my radiator back in order for me to get a new one.
I'm gonna see if they can just give me one right away from the shop so that I can finish this car quicker
PostSubject: Re: Dirty Dee's Build   August 9th 2010, 1:18 pm
Looking good Dee.
Very nice electric work!!!
PostSubject: Re: Dirty Dee's Build   August 11th 2010, 2:14 am
So, does this thread have RB20's wailing yet?
Can we fast forward to a soundclip of it with no exhaust shooting fireballs in your garage?
PostSubject: Re: Dirty Dee's Build   August 11th 2010, 2:15 am
yes please.
PostSubject: Re: Dirty Dee's Build   August 11th 2010, 7:45 pm
I'm working on it.
got inner z32 tie rods installed, spl outers, walbro fuel pump, and doing a final one over with the harness.
PostSubject: Re: Dirty Dee's Build   August 18th 2010, 11:36 pm
got the moroso battery box installed in the trunk. Had to drop the fuel tank to get it in. Friday I'm gonna wire it up to the engine bay.
driverside tension rod is bent to shit, so it looks like I need to buy some aftermarket ones this week.mad
Intercooler piping all hooked up, fuel lines, AAC and some other crap.
Swapped out the driverside headlight motor so I dont have to listen to the screech anymore
random shot
Dirty Dee's Build
Page 15 of 18Go to page : Previous  1 ... 9 ... 14, 15, 16, 17, 18  Next
