| Dirty Dee's Build | |
+46D*S Tomy Guns blklabel44 Trucky's bitch. s13 brian momo_nator altavelocidad D*S Homeboy. splitime Curtis DeAngelo Nelson II NlineSicks240 Adrian_S13 Felix Da Housecat Los Vlados Locos JakeS14 djexpo sad danielekfuj SPEEDTRIBE DJ Longdick his180sx SIMON D*S Dave D*S Roski whiterps13 jdmwackness RAD MIKE Circa 3006 007 Jay domdaaxe58 REVGASM gOtPUrPL3 Scuba Steve LeMoine Rated240R hs13kls 14k s14 mlhs14 D*S Trucky koh_ki240 D*S Dstar Stab Master Sharson just Mike tyler k c Nachtmensch Dirty Dee 50 posters |
JakeS14 Forum Frequenter
Number of posts : 486 Age : 34 Location : Chicago Vehicle : 97 240sx Reputation : -1
| Subject: Re: Dirty Dee's Build March 23rd 2009, 8:49 pm | |
| center box is dope. I might wana do that to mine | |
| Subject: Re: Dirty Dee's Build March 23rd 2009, 9:11 pm | |
| The pictures do not really show how nice it is.
When you see it in person the suede looks A LOT nicer. | |
| Subject: Re: Dirty Dee's Build March 23rd 2009, 11:16 pm | |
| chris.. *cough* you should do my glove box *cough* | |
| Subject: Re: Dirty Dee's Build March 23rd 2009, 11:39 pm | |
| - hs13kls wrote:
- chris..
*cough* you should do my glove box *cough* thats what i was thinking... | |
| Subject: Re: Dirty Dee's Build March 24th 2009, 5:27 pm | |
djexpo Forum Frequenter
Number of posts : 452 Age : 35 Location : Chicago Vehicle : 89 240sx Coupe Reputation : -1
| Subject: Re: Dirty Dee's Build March 24th 2009, 6:02 pm | |
| looks similar to vinyl, not fun | |
| Subject: Re: Dirty Dee's Build March 24th 2009, 6:46 pm | |
| How did the plastic you painted turn out? | |
| Subject: Re: Dirty Dee's Build March 24th 2009, 8:23 pm | |
| would it be harder to have vertical sections on the panel? | |
| Subject: Re: Dirty Dee's Build March 24th 2009, 8:27 pm | |
| Try sticking some more of that super glue in the sections that did not stick down dirty d. That may do the trick. Just do not get it in open sight, or glue your finger. | |
| Subject: Re: Dirty Dee's Build March 24th 2009, 11:16 pm | |
| - Stab Master Arson wrote:
- would it be harder to have vertical sections on the panel?
Vertical sections would not help. The trouble spots are the ends where it is indented. The material wasn't able to stretch in those areas, and would wrinkle up. | |
LeMoine Forum Frequenter
Number of posts : 456 Age : 32 Location : chi Reputation : 0
| Subject: Re: Dirty Dee's Build March 25th 2009, 11:16 pm | |
| I did this same thing with my last car and it came out ok. What I was told to do for the best results with those door panels is to cut that piece out from the panel. Wrap it. Then glue it back in with some special glue shit, maybe like jb weld or somthing. I was told this by the guy that does custom interiors at work. | |
| Also you should scotch guard that shit cause once it gets wet it discolors. | |
| Subject: Re: Dirty Dee's Build March 25th 2009, 11:53 pm | |
| meh. Most likely going to be redoing it in the summer with genuine suede instead of the fake stuff. got rid of the AIV and charcoal canister today as well as the respective vacuum lines. Also finally installed the altima fans I picked up from red over a year ago | |
| Subject: Re: Dirty Dee's Build March 26th 2009, 11:53 am | |
| ^ true that, you picked those up when you picked mine up! lmk if you have any problems i can try to help you over the phone.. lol did you get all those other lines blocked? | |
whiterps13 Post Enthusiast
Number of posts : 1385 Age : 36 Location : Rockford Vehicle : S4 Reputation : 11
| Subject: Re: Dirty Dee's Build March 26th 2009, 12:03 pm | |
| There is no right way to do the door panels other than getting it professionally done. I have tried numerous times, so has Broadfield, all with the same results. I did ithe Gucci in 1 piece and it looked fucking great. No creases, perfect stick, etc. It will stick for a month or so, but on super hot days they will peel. Even tired cutting out the panel, wrapping it, and fiberglassing back on. Same fucking thing.
Professionals not only use 2 pieces but the strength of their glue is much better. Nothing over the counter will hold for very long. Even industrial strength 3m in the can wont work. It would be nice to try and vacum seal the fabric like the factory did. | |
| Subject: Re: Dirty Dee's Build March 26th 2009, 12:35 pm | |
| Yea, I was able to block off all the lines. But I think I might rewire it so the fans only run when the car is on and temp is high instead of being based solely on temperature - whiterps13 wrote:
- There is no right way to do the door panels other than getting it professionally done.
Professionals not only use 2 pieces but the strength of their glue is much better. Nothing over the counter will hold for very long. Even industrial strength 3m in the can wont work. It would be nice to try and vacum seal the fabric like the factory did. Yea, I remember you talking about how broadfield was trying to figure out a way to do it with two pieces, and having a seam down the middle. But, I am just going to have it done professionally over the summer or fall | |
| Subject: Re: Dirty Dee's Build March 26th 2009, 3:52 pm | |
| toby is a cool guy, i talked and took pictures of he car a few months ago, he may do mine lol you need to get this damn car down to champaign | |
| Subject: Re: Dirty Dee's Build March 26th 2009, 4:06 pm | |
| mid june it will be down there. Btw, Kim, around what temperature did we set your fans to kick in?
started messing around with the front splitter/skid plate today. Drilled out some mounting holes and took a few measurements. Just need to get some mounting hardware and install it tomorrow. | |
| Subject: Re: Dirty Dee's Build March 26th 2009, 4:44 pm | |
| - Dirty Dee wrote:
- mid june it will be down there. Btw, Kim, around what temperature did we set your fans to kick in?
started messing around with the front splitter/skid plate today. Drilled out some mounting holes and took a few measurements. Just need to get some mounting hardware and install it tomorrow. oo, i honestly have no idea. i cant remember, i just set it at the middle (it corresponded to some temp like 180?) but i adjusted it from there. so i dont really know. i need to look at it again | |
| Subject: Re: Dirty Dee's Build May 20th 2009, 8:25 pm | |
| Italian suede. My brother knew someone who was able to get it at a cheaper price, so he ended up paying 18/sq. ft rather than 35/sq. ft. | |
| Subject: Re: Dirty Dee's Build May 20th 2009, 8:29 pm | |
| cool ass hell!
have you thought about wheel upgrade yet? | |
| Subject: Re: Dirty Dee's Build May 20th 2009, 8:30 pm | |
| I'm broke, and jobless until mid august.
so yea... | |
SIMON Post Whore
| Subject: Re: Dirty Dee's Build May 20th 2009, 8:36 pm | |
| Italian suede? classsssy! | |
| Subject: Re: Dirty Dee's Build November 9th 2009, 11:09 pm | |
| Subject: Re: Dirty Dee's Build | |
