 FS: S13 Parts ka24de engine, trans, kaaz diff & more
shiftin_sideways
Number of posts : 118
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Empty
PostSubject: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 5th 2014, 7:17 pm
EMAIL:Pm is best
PAYMENT: cash
ITEM: KA24DE  engine
PRICE: $200
SHIPPING: NO
DESCRIPTION:  bought  this  about  4  years  ago  as  a  spare. I  was  told  it  runs  fine.  engine  rotates  freely  by  hand.  Note: long  block  means  no  peripheral  accessories  i.e. no intake  manifold, no distributor, no fuel  injectors, etc.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_165908
ITEM: SR  trans
PRICE: $60
SHIPPING: NO
DESCRIPTION: bought  trans  about  5  years  ago, told doesn't  grind  and  no  leaks. never  installed  to  drive  and  see  if  it  was  true. the  trans  that  will  be  for  sale  will  be  the  one  on  the  left  in  picture  has  orange  overflow  tube  and  extension  housing. NOTE: trans  cross  member  in  picture  will  not  come  with  trans.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_162530-1
ITEM: KA  trans  with  SR  bellhousing
PRICE: $10
SHIPPING: NO
DESCRIPTION: grinds  in  2nd  gear, had  about  100,000  miles  on  it  when  pulled. buy  it  and  rebuild  the  internals  for  a  spare  is  my  suggestion  to  you.  the  trans  for  sale  will  be  the  one  in  the  picture  on  the  right.
ITEM: Kaaz  2  way  clutch  type  differential
PRICE: $640
SHIPPING: NO
DESCRIPTION: about  8 years  old, less than  10,000  miles  on  it, has  about  10  track  events  on  it. Just  replaced  the  diff  oil  a  month  ago.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_231359
ITEM: Powered  by  Max  version  1  Knuckles  and  control  arms
PRICE: $300
SHIPPING: NO
DESCRIPTION: I  got  these  knuckles  when  Powered  by  Max  first  started, maybe  4  years  ago(?). The  tie  rod  connection  on  stock  s13  knuckle  is  modified  to  allow  for  more  angle.  There  are  two  settings  for  tie  rod  angle.  The  control  arms  have  had  their  stock  bump  stops  removed  and  replace  with  an  adjustable  bump  stop.  The  arms  have  been  braced  for  less  torsion  of  control  arms.  I  drove  in  the  snow  once, which  explains  rust.  All  work  done  on  knuckles  and  control  arms  was  done  by  Powered  by  Max.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_192848
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_192753
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_193007
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_192933
ITEM: Uras  Tatsunootoshigo(sea  horse)
PRICE: $70
SHIPPING: Buyer  Pays
DESCRIPTION: these  allow  less  effort  in  pulling  ebrake  to  lock  up  rear  wheels. install  on  rear  brake  caliper  assemblies. Some  more  info  in  link.
http://www.rhdjapan.com/uras-tatsunootoshigo-s13.html
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_224801
picture  of  stock  vs.  Uras  stock  on  the  left
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_192540
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_192611
ITEM: YANACK Steering Rack Collar Set
PRICE: $80
DESCRIPTION:  solid  aluminum  bushings  for  steering rack  on  s13.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 5-27-11005
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 5-27-11006
ITEM: Apexi  Afc-Neo
PRICE: $100
DESCRIPTION: Bought  2  years   ago, told  it  works, never  tested  or  powered  up  to  see  if  works
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225841
ITEM:  various  ecu's  from  s13
PRICE: $60  each
DESCRIPTION:   2  #24  and  1  #28, one  of  them  is  for  auto  ka24de  in  s13  and  the  other  is  for  manual  ka24de  in  s13.  you  will  have  to  check  part  #'s  to  make  sure. Jim  Wolf  Technology  may  have  the  part  #'s  for  all  the  ecu's.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225330
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225308
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225253
ITEM:  steering  bushing  for  s13  from  touge  factory
PRICE: $40
DESCRIPTION:  steering  bushing  that  mounts  on  steering  column  above  u joint  in  steering  rack.  the  stock  bushing  is  located  near  the  firewall.
reduces  the  amount  in  play  between  the  steering  wheel  and  steering  rack.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225425
ITEM:  Jdm  steering  wheel
PRICE: $80
SHIPPING: NO
DESCRIPTION:  size  350  mm, semi dished, 6 bolt  pattern, color  is  maziora  purple. some  paint  chipping  on  back  on  wheel.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140716_195336
ITEM:  HJC  AR-10  helmet
PRICE: $160
SHIPPING: NO
DESCRIPTION: size  m, hat  sizes  7 1/8- 7 1/4, comes  with  clear  visor, gold tinted  visor(discontinued by  HJC), and helmet bag. Wore  for  about  10  events. Snell  Sa2005
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Photos052
ITEM:  Peak  performance  trans  mount  for  sr  or  ka
PRICE: $50
DESCRIPTION:  made  of  polyurethane
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_224741
ITEM:  Peak  performance  inner  tie  rods  with  spacer
PRICE: $50
DESCRIPTION: no  play  in  ball  joints used  for  1500  miles  and 3  track  events.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_224650
ITEM:  s13  steering  rack
PRICE: $40
SHIPPING: NO
DESCRIPTION:  no  leaks  when  pulled, hard  lines  have  no  rust
pic  below
ITEM:  flip  up  headlights  set
PRICE: $20
SHIPPING: NO
DESCRIPTION: complete  assembly  with  motors, last  time  operated lights lit, went up, but  not  down, don't know  if  motor  assembly  is  to  blame
pic  below
ITEM: s13  stock  shifter
PRICE: $5  each
DESCRIPTION:  hass  clip  and  plastic  retainer  intact
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_161030
ITEM: trans crossmember  for  manual  sr  or  ka
PRICE: $5  each
DESCRIPTION: comes  with  factory  rubber  trans  mount  in  good  condition
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_231521
ITEM: Destruction  warehouse  shift  know
PRICE: $25
DESCRIPTION: threaded  for  stock  s13  shifter, size  is  about  the  same  as  stock  s13  shift  knob
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_230318
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_230309
ITEM: ebrake lever  with  drift  knob, complete  ebrake line
PRICE: $30
DESCRIPTION:  ebrake lever  with  attached  cables  that  go  all  the  way  to  rear  calipers, pulled  from  a  car  with  about  100k  miles
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_230227
also  in  above  picture  are  wiper  arms, turn  signal  stalk, wiper  stock, wiper  motor, ash tray, flash, rear defrost, headlight flip switches all  $5,willing  to  ship all
ITEM: 5mm  spacer  for  4/5x114.3  hub  pattern
PRICE: $20  for  all  four
DESCRIPTION:  used  once
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_224840
ITEM: ignition  coil  for  ka24de
PRICE: $20
DESCRIPTION:  used  to  test  a  no  start  problem, other  than  that  not  used  since  bought  brand  new
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_225149
ITEM: fuel  rail  for  ka24de  no  injectors  included
PRICE: $5
DESCRIPTION:  didn't  test  fuel  rail  for  leaks, just took  out  injectors  for  another  engine
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140804_224915
ITEM:  stock  s13  axles
PRICE: $30 each
SHIPPING: NO
DESCRIPTION:  had  about  100k  miles  on  them  when  pulled, 3 track  events
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_162602
ITEM:  stock  s13  open  diff
PRICE: $20
SHIPPING: NO
DESCRIPTION: taken  out  of  car  with  100k  miles
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_153717
Also  in  above  pic, rear  lower  control arms, starter, and brake calipers(need  rebuild)  are  $5  dollars NO  SHIPPING
ITEM: A/C  components  for  s13  KA24DE
PRICE: $5  for  everything
SHIPPING: NO
DESCRIPTION:  don't  know  if  anything  works  or  leaks
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_162518
ITEM: key  cylinders  for  s13  hatch(don't know  if  fits  s13  coupe)
PRICE: $10
SHIPPING: NO
DESCRIPTION: key cylinders  for  both  front  doors, rear  hatch, glove box,and ignition  cylinder. all  lock and unlock with  one  key. suggest to  re  key  all  locks  for  a  new  key  so  new  key  won't  be  so  worn  down.
FS: S13  Parts ka24de engine, trans, kaaz  diff  & more 20140707_154129
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 6th 2014, 2:20 am
Would you want to sell just the gold helmet visor? And how much? Shoot me a PM.
shiftin_sideways
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 6th 2014, 6:22 pm
Trying to sell helmet with visors as a whole right now.
shiftin_sideways
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 9th 2014, 1:47 pm
headlights sold
Ace Combat Driver
Ace Combat Driver
Number of posts : 372
Vehicle : 180sx,
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 10th 2014, 2:15 pm
I want the uras levers. Text me 630-640-8665 juan
shiftin_sideways
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 10th 2014, 5:25 pm
^^^^^ text sent.
A/c stuff sold.
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 11th 2014, 10:06 pm
Still got the slip ons?
shiftin_sideways
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 12th 2014, 4:50 pm
^^^^^^Yeah, still got spacers.
shiftin_sideways
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeAugust 13th 2014, 8:41 pm
Key cylinders and dash buttons sold
PostSubject: Re: FS: S13 Parts ka24de engine, trans, kaaz diff & more   FS: S13  Parts ka24de engine, trans, kaaz  diff  & more Icon_minitimeSeptember 17th 2014, 4:13 pm
Change your mind on the helmet visor? Hahah
» WTB ka24de engine and 5 spd trans
» WTB ka24de engine & manual trans
» wtb ka24de engine and trans asap
» wtb Engine, trans, body parts, all for Zenki S14
» Leftover parts from ka24de part out, welded diff, and axles
