 GT Homologation Special
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
GT Homologation Special - Page 10 Empty
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeNovember 24th 2015, 6:09 pm
i actually really like the single opening front.
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeNovember 25th 2015, 8:59 am
I do too, but they're impossible to find. That bumper is the Bandoh front, which matches the kit. I have the Monocraft front bumper. The Bandoh GT300 car started by running a Monocraft body, but was later modified to their own design.
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeDecember 30th 2015, 2:14 pm
I just got my subframe back. The subframe was boxed in by Ill Garage and then powder coated.
GT Homologation Special - Page 10 Subframe1
GT Homologation Special - Page 10 Subframe2
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeJanuary 5th 2016, 6:47 pm
Headers acquired. I also forgot to notch the subframe for the rear header. It will come back out of the car, get cut up, welded, and powder coated again. Dammit.
GT Homologation Special - Page 10 WaD6K4P
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeJanuary 13th 2016, 1:00 pm
What a dick head. Hahaha
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeJune 2nd 2016, 11:03 pm
Damn Kevin!!!!
You have been busy.
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeJune 21st 2016, 8:26 pm
I bought a thing. Many other things have been done. More eventually. Or not.
GT Homologation Special - Page 10 3TVmOmW
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeJune 27th 2016, 4:39 pm
That top looks real sweet.
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeDecember 31st 2016, 5:23 pm
Just realizing that it has been nearly a year and I still haven't done this.
Things I did this year:
  • Finished the fuel system
  • Put the passenger side engine mount on properly
  • Decided to shave the mounting flange off the quarter panels and mount them like overs, on top of the factory quarters (better gaps, easier mounting, etc) Started on one
  • Custom Stance coilovers (short stroke dampers to clear axles and lower end links, shortened lower brackets to allow desired ride height)
  • Officially 5 lug all around after custom front hubs were made
  • Hardtop
Things left to do:
  • Notch subframe for the rear header
  • Wiring - Patch harness from the factory 2GR harness to the AEM Infinity connector, with extra plugs for; main relay, battery power, extra sensors, LCD data logger
  • Have the intermediate shaft machined with a grove 1/4" closer to the transmission for the carrier bearing
  • Exhaust Y pipe and muffler welded up
  • Radiator hard line relocation/solution to it exiting into the front header (Likely requires a fuel tank drop)
  • Final body panel fitment and fuel filler solution
  • Front tubs if the wheels don't clear
  • Paint
Plugged the factory FPR
GT Homologation Special - Page 10 ARtvmCR
5 Lug
GT Homologation Special - Page 10 AUAMpkZ
Current status, closing out 2016
GT Homologation Special - Page 10 KC3Rv9V
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeFebruary 11th 2017, 10:56 pm
Things left to do:
Started working on this today.
Pulled the subframe and fit the rear header for the first time.
GT Homologation Special - Page 10 BGFqql7
Made my rough cut after eyeballing it
GT Homologation Special - Page 10 IJneXop
GT Homologation Special - Page 10 QwrhPHZ
That's a pretty well calibrated eyeball.
GT Homologation Special - Page 10 SlGfFoj
Unfortunately I will need to cut more for clearance.
GT Homologation Special - Page 10 LRxH0R7
That looks pretty good. About 1" all around. I have solid poly mounts, so the motor shouldn't move much. I plan on making a heat shield with recessed nuts to attach it to.
GT Homologation Special - Page 10 FGWBnqy
I will need to add some bracing. With the help of CAD (cardboard aided design)...
GT Homologation Special - Page 10 CQXVbbD
GT Homologation Special - Page 10 INXrtY4
And to box in the new gaping hole...
GT Homologation Special - Page 10 YBvx2SO
Thinking about future bracing.
GT Homologation Special - Page 10 NK9ISdU
After doing all this, I was reading a thread on a V6 turbo MRS. He chopped the subframe and moved it up 50mm to correct bumpsteer (he also moved the trailing arm pickup up 50mm)
I'll probably go this route, since my suspension arms are reaching for the sky. I can't brace the bottom like he did, since my exhaust and engine mount is under there.
GT Homologation Special - Page 10 PDLDNjA
GT Homologation Special - Page 10 7uoH18O
GT Homologation Special - Page 10 Q3wYs75
GT Homologation Special - Page 10 UhhEjQz
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeFebruary 20th 2017, 2:52 am
I have high hopes for this thing. I wanna get down syndrome from looking at it in person. Shits gonna be great.
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeApril 2nd 2017, 1:45 pm
Got my intermediate shaft machined to move the carrier bearing 1/4" closer to the trans, allowing me to use a stock Sienna bracket bolted to the side of the block.
GT Homologation Special - Page 10 JpV5yU8
Decided to get the starter bolted in and start on the shift linkage stuff. The starter hit the cable bracket (my engine has the towing package oil/water cooler lines). I opted to just shave down the starter rather than fab a new solution. Started on the coolant lines. It will be run like a factory MRS. I need some parts to finish it.
GT Homologation Special - Page 10 O1NCqo3
Lastly I started on the shift selector mechanism. The groove on the outside needs to be turned 180ยบ, while everything internal needs to remain in the same location, including the arm next to the groove. A simply grinding down of the spline on the opposite side of the shaft and some welding will solve this issue.
GT Homologation Special - Page 10 CkU0ZU0
PostSubject: Re: GT Homologation Special   GT Homologation Special - Page 10 Icon_minitimeOctober 25th 2017, 11:19 am
Will you be done by(for) next year? I would really like to see this done.
Page 10 of 10Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
» VAL's SPECIAL GENERAL MEETING - Sunday 16th October 2011
» Are any of you guys doing anything special to combat
» Garmin Etrex on Special - Save $$$
» WWE Special - King of the Ring
» Special carpet
