 91' s13 w/1jz blitz 03's
Number of posts : 288
Vehicle : 1990 240sx
91' s13 w/1jz blitz 03's Empty
PostSubject: 91' s13 w/1jz blitz 03's   91' s13 w/1jz blitz 03's Icon_minitimeMay 11th 2013, 9:26 am
Item: 1991 Nissan 240sx w/1jzgte r154 trans
Place: Chicagoland
Price: $11,000 OBO yes, it's high, but I have over $16k into the car and i know i'm just going to get low balled. Sp if youre willing to work with me i can work with you! No trades unless it's an FD Pre OBD2
Contact: PM or Email at s13brian at gmail dot com
Description:
Was originally a Florida car, ZERO rust. Brought it home and stripped it down to a bare shell. Sprayed the entire interior with Lizard Skin sound and he dampening material. All chassis parts have less then 2k miles on them. All 1jz swap parts have less then 1k miles on them. Car was only driven during the summer from May to September and has never seen snow.
If you're a serious buyer I will get specific pictures of anything on the car you would like.
= Steering/Suspension =
Stance GR+ coilovers
Peak Performance inner tie rods
Oem s14 outer tie rods
Peak Performance tension rods
Peak Performance toe rods
Peak Performance RUCAS
PowerByMax solid subframe spacers
Oem power steering rack
Solid steering bushing
Oem s14front hubs
S14 lower control arms
S14 knuckles
S14 rear hubs with new wheels bearings pressed in
New steering rack bushings
= Transmission =
R154 transmission
Driftmotion 11lb lightweight flywheel
ACT 6 puck sprung clutch
ACT heavy duty pressure plate
r154 slave cylinder
Chase Bays stainless clutch line
New clutch release bearing
NEw clutch fork
ARP flywheel bolts
= Engine =
1jz with stock twin turbos
1jz cams seals
1jz complete gasket set
1jz timing belt hydraulic tensioner
Greddy 1jz timing belt
1jz spark plug cover bolts
1jz arp head stuff
1jz thermosts
2jz water pump
1jz serpentine belt
1jz version 2 aluminum pulley kit
1jz serpentine belt tensioner
1jz throttle position sensor
1jz coil back connectors
chase bays power steering reservior
chase bays power steering lines
chase bay coolant overflow tank
mishimoto s14 radiator
2 15' Spal pull fans
Aeromotive fuel pressure regulator
= Interior =
Lizard Skin
Full interior
AutoPower 4 point cage with harness bar
Drivers Team Tech 4 point harness
Passenger Team Tech 4 point harness
oem passenger seat
RaceTech 1000 drivers seat
Nagisa dual lock seat rails
Custom gauge cluster
-Stack Tach
-Stack fuel level
-Stack oil pressure
-Stack Water Temp
-Autometer boost gauge
-Shift light / turn signal and check engine light
Relocated battery to trunk
OMP Corsica steering wheel
Works Bell short hub
= Paint/Exterior =
PBJ dodge ram blue
Origin stylish rear bumper
Vertex front bumper
Vertex side skirts
Oem metal all around / no pull only roll
Origin position lights
= Braking =
Brembo front oem rotros
Brembo rear oem rotors
Hawk Hp+ pads front
Project MU D1 spec pads rear
New Mater Cylinder
Dot 4 brake fluid
OEM calipers
= Wheels/Tires =
Federal 595ss rear 235-40-17
Federal 595Evo front 215-40-12
Blitz 03's
front 17x9 plus 15 with spacer
rear 17x10 plus 28 with spacer
PIctures:
91' s13 w/1jz blitz 03's 1jzenginebay_zpsfc3c1314
91' s13 w/1jz blitz 03's Stackcluster_zps8a83feb8
91' s13 w/1jz blitz 03's Interior1_zpseb9aa015
91' s13 w/1jz blitz 03's Paint3_zps87ce599e
91' s13 w/1jz blitz 03's Paint2_zpsb45b6bf8
91' s13 w/1jz blitz 03's 5c339a47-d311-471b-bd0e-9e9af55e5d21_zps38e610a2
91' s13 w/1jz blitz 03's Bitzquarter_zps7f0a583c
91' s13 w/1jz blitz 03's Db3d6e23-012b-46c4-9961-394be33bb318_zpsafadeeef
» BLITZ SS, other stuff.
» WTS T25 / Blitz DD Bov w/ Hardpipe
» FS: Blitz BOV w/ SR/KA hotpipe
» Feeler: Blitz DD BOV w/6incher
» s14 coilovers and Blitz exhausti
