| Valve Cover Leak wont stop | |
Zubasky Fucking Noob
Number of posts : 17 Age : 40 Location : Boulder, CO Vehicle : S14 240sx S14 SR20det Reputation : 0
| Subject: Valve Cover Leak wont stop November 3rd 2011, 7:30 am | |
| Ive done it about 5 or six times now and the back of my ka24de wont stop leaking. It leaks at the cam lobes on the back side of the block, both of them. The first coulpe times I tried new rtv. Then I bought a new oem gasket and more rtv. The bolts had been stripped out and I tapped in some bigger ones. I cant believe this is happening. Does anyone have a way to stop this leak? | |
ka24orce Ace Combat Driver
Number of posts : 372 Age : 40 Location : Riverside Vehicle : 180sx, Reputation : 11
| Subject: Re: Valve Cover Leak wont stop November 3rd 2011, 10:27 am | |
| You probably ruined the surface on the head. Get new head | |
Number of posts : 768 Age : 34 Location : WAY north Chi-town, Illinois Vehicle : dirty girls Reputation : 3
| Subject: Re: Valve Cover Leak wont stop November 3rd 2011, 6:18 pm | |
| ultra grey sealant is the only shit that works | |
| Subject: Re: Valve Cover Leak wont stop November 6th 2011, 1:01 am | |
| - ka24orce wrote:
- You probably ruined the surface on the head. Get new head
It could be the head but it looks like the leak is above the point where the head meats the block cause its all wet just below the valve cover where the cam lobes are. | |
| Subject: Re: Valve Cover Leak wont stop November 6th 2011, 1:02 am | |
| And cant I just get the head resurfaced anyway if thats the case? | |
| Subject: Re: Valve Cover Leak wont stop November 6th 2011, 1:35 am | |
| you're an idiot, your head gasket wouldn't leak oil. He said you ruined the surface on your head. as in the surface that the valve cover gasket needs to seal against. You probably fucked it up.
that or you're just a complete moron and can't figure out how to change a gasket. | |
| Subject: Re: Valve Cover Leak wont stop November 6th 2011, 1:40 am | |
| Make sure the gasket lays flat. Use a RTV sealer in corners of the cam seals. Simple install.
Bring the car to me, I'll change it for $40, including a new seal. | |
| Subject: Re: Valve Cover Leak wont stop November 6th 2011, 8:20 am | |
| - Nachtmensch wrote:
- Make sure the gasket lays flat. Use a RTV sealer in corners of the cam seals. Simple install.
Bring the car to me, I'll change it for $40, including a new seal. Thanks for the offer but thats what I have done. | |
| Subject: Re: Valve Cover Leak wont stop | |
