ghost420 Light Duty Poster
Number of posts : 101 Age : 37 Reputation : -3
| Subject: Camber plates. August 31st 2011, 7:27 pm | |
| Can i adjust them while the cars still on the ground? or do i have to disconnect everything again and shit? | |
dorikin717 Established Member
| Subject: Re: Camber plates. August 31st 2011, 7:37 pm | |
| Subject: Re: Camber plates. August 31st 2011, 7:44 pm | |
| You have to jack it up, take off the 17mm bolts that connect to the spindle, then loosen the large nut on top (forgot what size) and then adjust camber and put it back together. | |
| Subject: Re: Camber plates. August 31st 2011, 7:46 pm | |
ka24orce Ace Combat Driver
Number of posts : 372 Age : 40 Location : Riverside Vehicle : 180sx, Reputation : 11
| Subject: Re: Camber plates. August 31st 2011, 8:10 pm | |
| - RAD MIKE wrote:
- You have to jack it up, take off the 17mm bolts that connect to the spindle, then loosen the large nut on top (forgot what size) and then adjust camber and put it back together.
Huh? Jus jack it up... Loosen 4 Allen bolts on plate... Adjust... Tighten 4 Allen bolts... Lower | |
| Subject: Re: Camber plates. August 31st 2011, 8:22 pm | |
| ^^^ thts what i thought... | |
| Subject: Re: Camber plates. | |
