 Feeler: rb20 fastback
8 posters
Feeler: rb20 fastback Empty
PostSubject: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 9th 2011, 7:32 pm
Kinda getting tired of working on cars, and I need a daily bad.
Curious to see if anyone would want to buy it.
Would like $8,500.
List of Parts:
Wheels, Suspension, Brakes:
255/40/17 hankook rs-3s
17x9 Grenades
SPL V3 tension rods
SPL Tie Rod Ends
Z32 Inner Tie rods
Nismo Power Brace
Cusco Zero-2E Coilovers
Rear Control Arms except RLCA(all Megan)
braided steel brake lines
braided steel clutch line
hp slotted rotors
Hawk pads on front
gorilla lug nuts
gorilla lock nuts
energy suspension bushings (PS, sway bars, LCA F and R)
Nismo 1.5 Way
Act 6 puck sprung
Engine Bay Misc:
BMC Heat Shield
power steeering line RB20
downpipe w/ O2 and A/F bung
mushimoto radiator
circuit sport catch can
slim line fans
autozone fan temp relay
spot welded engine bay
Engine and Performance:
rebuild gasket kit
piston rings
crank collar
ALC Race bearings (rods)
ALC main bearings
ARP studs (rods)
ARP studs (head)
GTR Oil Pump
OEM Water Pump
Nismo Thermostat
Tomei Cam Gears
Timing Belt
Tensioner and Idler Pulleys
Top Hat Front Facing Plenum
Nistune
550cc daetchwerks injectors
255 walbro fuel pump
nismo fpr
fuel pressure gauge
FMIC
z32 maf
hks ssqv bov
rb25 turbo
Top Hat motor and Trans Mounts
kelford cams 10.2mm 260
bronze valve guides
3 angle valve
port & polished
kelford valve springs
Circuit Sport Exhaust
Interior & electronics
OMP Corsica Wheel 350mm
NRG Short Hub
NRG short QR
Greddy boost gauge
Greddy oil pressure gauge
Greddy water temp gauge
Greddy egt gauge
Moroso battery box
battery relocation
Optima Red top
dakota digital tach converter
180sx headliner
180sx manual seatbelts
CS aluminum steering bushing
Exterior Parts and Lighting:
Kouki Side Skirts
VS type 6 front bumper
Kouki position lights
Kouki turn signals
Kouki rear lamps and trim
SARD Vortex Generators
The bad:
-EX camshaft seal is leaking, needs to be replaced
-minor rust starting by fenders due to baseball bat roll
-paint chipped on fenders from roll
-front bumper has multiple cracks
-no A/C
-radio antenna needs to be replaced (aftermarket one that mounts on inside of window)
Will add as I remember more. Also will post more detailed pics if there is interest.
Feeler: rb20 fastback IMG_5515
Feeler: rb20 fastback IMG_5517
Feeler: rb20 fastback IMG_5518
Feeler: rb20 fastback IMG_5520
Feeler: rb20 fastback IMG_5519
Feeler: rb20 fastback IMG_3759
proof of work for people who dont know:
Feeler: rb20 fastback IMG_0277
Feeler: rb20 fastback IMG_0275
Feeler: rb20 fastback IMG_0251
Feeler: rb20 fastback IMG_0487
Feeler: rb20 fastback IMG_0704
And dyno:
Feeler: rb20 fastback Untitled
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 9th 2011, 7:45 pm
=[ very nice car dee. glws
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 9th 2011, 11:06 pm
Car is super clean. GLWS. Wish you would drive it a bit more Sad
Number of posts : 1013
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 9th 2011, 11:17 pm
<3 the wheels!!! trade me hah gl ws super cool car
Number of posts : 2188
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 9th 2011, 11:20 pm
As Kevin said, this car is really clean. I wish you wouldn't sell it, but best of luck, Chris.
It is also worth mentioning that if anyone who is not familiar with Chris wants to buy the car; everything on the car was done right, with no corners cut, especially on the motor build process.
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 10th 2011, 1:00 am
yeah bro
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 10th 2011, 1:50 am
hahaha
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 10th 2011, 9:17 pm
willing to sell the grenades?
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 10th 2011, 11:53 pm
tires would have to come with the wheels if someone were to buy them
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 11th 2011, 2:43 am
How much are you asking for them?
PostSubject: Re: Feeler: rb20 fastback   Feeler: rb20 fastback Icon_minitimeAugust 11th 2011, 8:40 am
1100
» feeler : s13 hatch
» rb20 injectors
» WTB RB20 ignition module
» Feeler: S13 FB Shell
» Feeler: Truckys S13.
