 s13 abs actuator removal/abs delete
shiftmikey
shiftmikey
Number of posts : 94
Vehicle : s13
s13 abs actuator removal/abs delete Empty
PostSubject: s13 abs actuator removal/abs delete   s13 abs actuator removal/abs delete Icon_minitimeJune 30th 2011, 7:09 pm
as of last monday my abs actuator sprung a leak on one of the lines that
leads to a bleeder on top of it. it is now spraying brake fluid all
over my engine bay and also making my pedal and brakes unresponsive
under heavy braking. and its leaking fluid all over underneath the unit
and my paint is peeling up. so im taking it out. i cant fond one for
sale around me that i can go pick up and my abs dosent work anyway. i
know there is a part i can order from nissan
for the front brakes and from what i understand i can just connect the
lines for the rears and be done with that. im now left wondering if i
absolutely need to use the part from nissan or if i can just use a
regular "T" fitting from the hardware store. i don't think there is
anything involved with proportioning in the part from nissan. obviously
there isent in the t i have in front of me. that's the only thing i cant
find an answer for. there's a few write ups i found on google but non
of them have pictures or any of that stuff.
is leaking/spraying from 4 pinholes on the smaller tube that goes to the bleeder.
s13 abs actuator removal/abs delete DSCN2627
the one on the left is the "T" for the front and the one on the right is the male to male connector for the rears
s13 abs actuator removal/abs delete DSCN2629
shiftmikey
shiftmikey
Vehicle : s13
PostSubject: Re: s13 abs actuator removal/abs delete   s13 abs actuator removal/abs delete Icon_minitimeJuly 11th 2011, 12:34 pm
i ended up just buying the part from nissan. its the same shit as the "T" above. aside of being 12$ instead of 6$. my brakes work fine now. if anyone wants a picture or help doing thtis shit lmk i guess.
» wtb s13 abs actuator
» David's CA18DET build-up thread!
» hatch removal
» (Nackers!) I need help with HKS wastegate Actuator!
» spoiler removal on s13 coupe
