Rolling the dice and riding the dragon since the year of our lord, 2006.
 high idle at stops help!!!!!
bks14
Number of posts: 24
Vehicle: 1996 240sx s14
PostSubject: high idle at stops help!!!!!   April 24th 2011, 5:50 pm
hey guys, i need help idk wat to do im goin nuts.
i just picked up mi first sr20 redtop and it runs great crusin and full throttle but the thing that i dont get is wen im just crusing and i come to a stop light mi car rev up to 2000 and sometimes just stays there
anyone got any ideas???? help plz theanks
mi set up i isis intake manifold
isis intercooler piping
obx turbo manifold
isis full exhaust
walbro 255 fuel pump
apexi safc
and everything else is basicly stock
rc1honda
Number of posts: 81
PostSubject: Re: high idle at stops help!!!!!   April 24th 2011, 8:58 pm
Probably due to you blow of valve if you have one. Recirculate it, that should stop the problem. The SAFC has a decel air tune setting but i dont know how to tune it.
The problem is due to air that gets metered through the MAF is no longer there causing a rich state and the ECU stumbles trying to find the proper timing and load setting.
Number of posts: 1403
Vehicle: 240sx
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 12:39 am
could be the idle air control valve on the intake.i had to adjust mine when i put on my isis intake
Tipsy Turtle!
Tipsy Turtle!
Number of posts: 10827
Vehicle: ZZW, SW
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 4:20 am
vacuum leak. check at the fuel injector grommets into the manifold. the only isis intake manifold i saw first hand, the injector spacing was incorrect using a stock fuel rail. there was no remedy. stock or greddy is better.
NACHTMENSCH
Intoxicated Tortoises
Vehicle: 240sx
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 2:06 pm
injector spacing was definitely not right on the polished isis i had but the one that wasnt polished was fine.if i had to do it over again i would just save the money and keep the stock intake on there unless i was doing an outrageous build
Tipsy Turtle!
Tipsy Turtle!
Vehicle: ZZW, SW
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 3:46 pm
yeah, this one was polished as well
NACHTMENSCH
bks14
Number of posts: 24
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 8:49 pm
thanks for the help...mi bov is on the hot pipe and its a hks ssq would that have somethin to do with it???
bks14
Number of posts: 24
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 9:13 pm
hey would a g20 iacv work with mi sr20????
Number of posts: 537
Vehicle: Gay 350z Vert
PostSubject: Re: high idle at stops help!!!!!   April 25th 2011, 10:11 pm
Prolly not, they are always closed at idle.
» "The quality here is not Swiss, but it's high".....Sure
» Mages got way to high damage.
» Okanagan High Rim Trail
» My new mini High Banker
» Sell Fresh Checked Dumps, Cvv n Fullz With High % Turnover, Bank Log Ins n Skimmers..
