 1996 Nissan 200sx SR20VET AWD AWD
boosted russian
Number of posts : 120
1996 Nissan 200sx SR20VET AWD AWD Empty
PostSubject: 1996 Nissan 200sx SR20VET AWD AWD   1996 Nissan 200sx SR20VET AWD AWD Icon_minitimeMarch 29th 2011, 3:06 pm
Here is your chance to buy something ONE of a kind. I will have the car tomorrow and will snap some pictures of it. The turbo Inlet sits in the fog light of the bumper. This car will be up for sale for 4 weeks before it is parted out. After it is parted out I am going to put a ka24de in it and make it RWD. If you want an sr20det in it, you can make arrangements with me and I will install a sr20.
PICTURES TOMORROW
PRICE: 9,000 OR BEST OFFER
I WILL INCLUDE the original title PLUS: A 1995 TITLE WITH THE CAR if you want to play that game and AVOID emissions.
Here is my 96 awd 200sx for sale. It is not 100% complete yet, with a little time and effort this will be a truely one of a kind car. In it current state it will run and drive but will need to be hauled away. No tire kickers, low ballers or flakers.
Mods:
know I am going to forget some stuff but here we go.
Sr20det u12
86mm bore
Je 8.5:1 forged pistons
Eagle forged rods
Cometic headgasket
Arp Main studs
Arp Head studs
Sr20ve head
Sr20ve oil pump
New Oem water pump
Gspec crank and water pump pullies
Custom steel cam gears
Prothane motor mount inserts
Custom forward facing twin scroll manifold
Twin 1 bar 38mm wastegates
Borgwarner twin scroll t366
Custom intercooler v banded to turbo outlet
Hks SSQV welded to intercooler
Z32 maf sensor
Motron 65lbs injectors
Msd digital 6 ignition box
OSG triple disc clutch
S14 clutch pedal and master cylinder
Oem Gtir trans and transfer case I have 2 sets
Driveshaft shop custom driveshaft
Custom made rear axles
Oem Gtir rear diff
Oem Gtir front axles with G20 outer joints
Full 5 lug swap
Nismo extended wheel studs in front
94 maxima spindles
98 maxima front brakes
98 240sx rear brakes
Stainless steel brake lines
Tein b14 basics w/ front pillowball mounts
S14 rear subframe
Wicked tuning rear camber, toe and traction bars
15 gallon sump style fuel cell
Fuel lab dc brushless 1000hp fuel pump
-8an stainless fuel feed lines
-6an stainless fuel return lines
Aeromotive fuel pressure regulator
FTF fuel rail
Greddy Egt, Boost, Wideband peak and hold gauges
Greddy mss for the ve
Cyberdyne oil temp & pressure, fuel pressure,h20 temp
Anderson ford loggable wideband
Jwt ecu for 72lbs injectors, big turbo, z32 maf
tenzo R grey/ black seats
Black acc carpet kit
Jdm radio bezel with card holder
Nismo shift knob
Fiber images cf hood painted black
Spoiler deleted from trunk
Jdm black headlights and corners
Lucino grill
6 point roll bar welded in
Optima redtop with billet mount
That all I can think of at the moment but I know there is more. I also have a few boxes of extra parts.
What need to be completed:
It doesnt want to idle
Exhaust needs cut and welded up-I have most of the parts to complete
Rear seat area to back of trunk needs a cover made
Engine harness needs tuck finished
Ve needs wired to the MSS
Coil needs mounted
Battery needs mounted
Alignment
Both diffs need drilled for larger bolts
boosted russian
PostSubject: Re: 1996 Nissan 200sx SR20VET AWD AWD   1996 Nissan 200sx SR20VET AWD AWD Icon_minitimeMarch 30th 2011, 3:16 pm
1996 Nissan 200sx SR20VET AWD AWD IMAG0717
1996 Nissan 200sx SR20VET AWD AWD IMAG0718
1996 Nissan 200sx SR20VET AWD AWD IMAG0719
1996 Nissan 200sx SR20VET AWD AWD IMAG0716
1996 Nissan 200sx SR20VET AWD AWD IMAG0720
boosted russian
PostSubject: Re: 1996 Nissan 200sx SR20VET AWD AWD   1996 Nissan 200sx SR20VET AWD AWD Icon_minitimeMarch 31st 2011, 9:08 pm
Bump
Anybody interested in this car with the following
5 lug conversion
Tein coilovers
Fuel cell
Walbro External fuel pump
17" fn01rc's
Welded Cage
WITH a Ka24de, setup for rwd, running and driving for 3,000?
» 1987 Nissan 200SX (S12) !!
» FS: Turbo from a 1996 nissan skyline
» FS: 1996 240sx (super clean, coilovers, intake, exhaust)
» 96 200sx se for sale $2100 obo no trades
» WTB 1996 AC Lines
