 Hydro E-brake's...
Hydro E-brake's... Empty
PostSubject: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 28th 2010, 1:16 pm
Im looking into picking up a Hydro-e brake, and I wanted
to get some input on them.
Brands/ mounting location/ fuction/ performance/ DIY intall.
I know a couple of people that have cool e-brake set ups.
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 28th 2010, 1:30 pm
IMO the driftworks setup is the only way to go. High quality + affordable + still works as a parking brake + pedal braking wont be affected/affect ebraking when used at the same time. Thats the route I plan to go when its time for one.
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 28th 2010, 1:33 pm
Ive been looking at that one for a while.
But can you position it standing up to??
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 29th 2010, 4:13 pm
"Can be used or use in both the normal position or in the upright position.
Swapping between normal and upright is a simple case of removing a couple of circlips and flipping the lever over."
Website says you can.
revgasm_josh
Number of posts : 50
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 29th 2010, 4:53 pm
i dont really understand why people go with hydro ebrakes?
properly adjusted ebrake/cables with shit pads will lock up the rears.
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 29th 2010, 4:56 pm
eh, my ebrake is so fucked up its not worth fixing. I would need new everything, from the lever to the calipers. hydro ebrake would be cheaper and more reliable.
if i had a good working ebrake, or one that I could easily fix, i wouldnt ever think about a hydro setup. But mine is so FUBAR it just makes sense to upgrade.
revgasm_josh
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 29th 2010, 5:04 pm
word, all i know is all the ones i've experienced pretty much lock up the brake pedal when u pull on the handle (which sux)
are there hydro set ups with separate lines?
PostSubject: Re: Hydro E-brake's...   Hydro E-brake's... Icon_minitimeDecember 29th 2010, 5:28 pm
staging brakes do that, like those CNC units everyone seems to have. The driftworks setup doesnt effect pedal braking at all.
Hydro E-brake's...
» 300zx brakes
» q45 maf/brakes/ps cooler
» Q45 Parts, Brakes, Diffs, etc.
» SS lines front pair for s14 brakes
» FS: s13 NEW OEM suspension brakes upgrades $45 sale!!
