 since my build got deleted?
Number of posts : 1053
since my build got deleted? Empty
PostSubject: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 20th 2010, 7:26 pm
some background of what happened.
sold the s13 :/ shouldve never done that. i thought i wanted a vip car.
got a 99 q45T awesome car. drove it till a few weeks ago. and traded for this s14.
there were A LOT of things wrong with it.
the trans would grind from 4th to 5th and in reverse. (previous owner said it was the shifter, i bought a new short throw and it didnt really fix anything)
came with
stock front bumper and a "invader" style bumper which i threw away, it didnt belong on a car.
built KA with high compression BC cams and what not. pretty quick and sounds cool
a z32 vlsd
i motoria exhaust (ive never heard of it, but it sounds good)
edm kouki tails (i noticed they are grey instead of black)
"nismo" sides and rear. really good fitment. just not my style.
stock s13 seat bolts that had 4 bolts total holding them both in.
ebay steering wheel.
automatic fan that went all around the entire motor bay, in the cabin hooked up to a fuse for the radio as power.
radio in the car didnt do anything but had a wire coming off of it so you could turn on the fan.. Face Palm
headlights that had all broken brackets, and zip tied on.
since my build got deleted? P1011120
since my build got deleted? P1011117
since my build got deleted? P1011112
then i started noticing a trend. if anything was supposed to have X amount of bolts holding it on, it usually had half of those.
i decided to look deeper in the car because everything felt clunky.
took forever to get the damn lugs off because they used these dumb things
since my build got deleted? Image-1
got new lugs
jack the car up and i noticed there is one aftermarket RUCA and one stock one. i noticed why the car sounded like it was going to break when it hit bumps. ALL THE BOLTS FOR THE REAR SUSPENSION WERE HAND TIGHT. pretty sketchy.
i decided to buy new suspension parts but then noticed there was a 12mm bolt holding on the rucas, and toe. and one side didnt even have a nut on it.. and almost every bolt was a different size. so i went to ACE and replaced all my bolts with grade 8 ones for about 20 dollars.
i then ordered some PBM links from a guy on zilvia.
got new head lights without broken brackets.
had to swap the lense over because the one i got didnt have them.
i didnt have the car for a day before i was swapping stuff out. tired of that interior. threw away the seats and put mine in with my steering wheel set up
got my CF chargespeed seat back in, and s14 seat. i love this interior. the passenger seat has been in almost all my 240s.
first night i had it [img width=600 height=450]https://2img.net/h/i1017.photobucket.com/albums/af293/hs13kls/image.jpg[/img]
got my links. and i decided to clean them thoroughly and used anti seize
since my build got deleted? IMG_0124
since my build got deleted? _MG_0119
ordered my wheels and they came rather fast
nothing exciting just 18x9.5 +15 225/40 tires
since my build got deleted? _MG_0120
then i noticed something leaking.
the freeze plug was dripping coolant. so i have to fix that thing soon.
since my build got deleted? Image-3
next day i decided to do some more work on the car and fix how the battery was mounted.. it wasnt mounted really at all. just was getting thrown around in the trunk. and then noticed all the rust.
i spent a few hours sanding/wire brushing all the rust off.. POR15'd it and then used truck bed liner this time.
cut a few holes out that had too much rust and welded a new plate in there, and welded a battery bracket in too.
since my build got deleted? Image-6
next day finished the paint on the trunk
since my build got deleted? _MG_0117
since my build got deleted? _MG_0047
since my build got deleted? _MG_0048
since my build got deleted? _MG_0045
decided to put the wheels on the car and lower it a lot
since my build got deleted? Image-7
wasnt enough yet
since my build got deleted? Image-8
put my spacers on so my effective offset up front is -5 and 0 in the rear on stock metal
went to the shop to work on the car
since my build got deleted? Image-11
my buddy just turboed his gsr, and got the motor built. sounds real clean
got a navan bumper from around town somehow, just came across it.
needed some work..
since my build got deleted? Image-9
but got it mounted.
next day i primed it
since my build got deleted? Image-10
and 2 days later
since my build got deleted? _MG_0016
if you notice, i didnt do any work to it. (as far as prepping it)
right before paint
since my build got deleted? Image-16
but the paint is flawless
since my build got deleted? _MG_0014
having this car this low isnt easy. i ran through my harness later in the day.
so i decided to re route it in the bay like my old coupe. i had to extend a lot of wires..
huge pain in the ass
since my build got deleted? Image-12
since my build got deleted? _MG_0040
cleaned up the bay since my build got deleted? _MG_0039
last one.
since my build got deleted? _MG_0074
if you noticed a built a bike last year, shortly after. i built this one too.
since my build got deleted? _MG_0061
made a pad
since my build got deleted? _MG_0063
got bored and replaced my front wheel with purple nipples
since my build got deleted? _MG_0064
since my build got deleted? _MG_0066
got some grips
since my build got deleted? _MG_0065
got a nice 17 t cog since my build got deleted? _MG_0070
kinda had a little shoot of the car in the current state.
sorry my ISO setting was off. and im too lazy to retake the pictures
since my build got deleted? _MG_0046
since my build got deleted? _MG_0060
getting in this garage is a pain
since my build got deleted? _MG_0052
since my build got deleted? _MG_0033
hood looks like shit
since my build got deleted? _MG_0034
since my build got deleted? _MG_0024
since my build got deleted? _MG_0028
since my build got deleted? _MG_0010
its a little low
since my build got deleted? _MG_0003
since my build got deleted? _MG_0001
oh if anyone was wondering, that bike is mine too
2005 600f4i
since my build got deleted? IMG_0057
i have all the plastics, just running a "street fighter" front. has a cage, 12 o clock bar, two brother exhaust, swapped the sprockets, but i have the originals.
quick, fun bike. i might be interested in selling it if anyone wants it.
oh yea. IVE OWNED THE CAR FOR 3 WEEKS
PLANS:
get corner lights,
r33 ebrake cables, and a Ebrake handle (so if anyone has a s14 handle/r33 cables holler at me)
SR swap (its in the works, i finally saved enough money to do a swap. just getting the motor prepped grandma's penis good leak down. with in 3-4%)
get a welded or a 2way the vlsd works, just not for me. i liked my old diff set up in my coupe
25mm spacers in the rear.
bash bar, and maybe V mount?
i kinda want overs now. and new side skirts.
maybe get turn signals too and a BC spec 2 exhaust like my old 240 lol
http://www.leagueltd.com
Number of posts : 817
PostSubject: Re: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 20th 2010, 9:40 pm
It probably got deleted for being so cocky about swapping a sr in 4 hours. G G G G GGGG GET THE FUCK OUT OF HERE!
PostSubject: Re: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 21st 2010, 12:52 am
cocky? i was just saying its easy.
btw. it only took 1 hour and 20 mins. its not like i had the sr in my car running. it just took that long to pull it.
BRO
PostSubject: Re: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 21st 2010, 12:18 pm
7:20
since my build got deleted? IMG_0037
i got a z32 maf, mines ECU, safc 2, IC piping, 3in downpipe. etc.
since my build got deleted? IMG_0040
got the IC piping off
since my build got deleted? IMG_0041
since my build got deleted? IMG_0045
i ordered a new oilpan from TF this one looked dented..
since my build got deleted? IMG_0048
since my build got deleted? IMG_0046
ready to pull it
since my build got deleted? IMG_0049
since my build got deleted? IMG_0050
done: 8:40
since my build got deleted? IMG_0051
PostSubject: Re: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 21st 2010, 12:30 pm
just got a AEM wideband, and new turbo outlet. all new gaskets, new pan, hks bov some rad hoes and a few other things.
putting the motor in tomorrow.
just took some time to wash it down, clean it up and paint the valve cover and replaced those gaskets at the same time
PostSubject: Re: since my build got deleted?   since my build got deleted? Icon_minitimeSeptember 21st 2010, 3:52 pm
Your "build" thread got deleted because you do ALL TYPES of super annoying dumb shit like bold out " OH YEAH. IVE HAD THE CAR FOR 3 WEEKS" and other dumb shit like that. Are you fucking 12? Nobody's fucking impressed. You got some funk ass s14 with ugly ass "aero" and put some fucking battles on it and lowered it. People on here build whole fucking cars in days.
Here are some examples of you being a faggot.
Quote :
7:20
ready to pull it
done: 8:40
Nobody types like that and nobody gives a fuck what your "time" was. This made me and my friends lol super hard.
Quote :
2005 600f4i
Nobody cares about your $2000 600cc and that made me mega lol too.
Your seriously like one of those lying showoff kids on Forza. I dont understand what is wrong with car kids like you. Why do you talk like that? DId you never have possesions or DO anything growing up? Now I see why niggas was talkin shit about you talking about your "driving". Hahahahaha.
Take this shit on nico or something, we dont get down like that down here. And if your gonna cry about it, dont bother, ill just ban you to avoid the headache.
Learn to stop talking like a showoff teenager.
» deleted
» ka-t build
» E46 M3 CSL build (NO 56K)
» the car that will never run!
» The slow build of my s13
