 Test fitting =)
boosted russian
Number of posts : 120
Test fitting =) Empty
PostSubject: Test fitting =)   Test fitting =) Icon_minitimeJanuary 5th 2010, 8:52 pm
So, I dont post often but here goes. Just a couple of pictures of what I been up to. A lot of test fitting and back n forth.
Test fitting =) 18543_406804845712_695975712_10507454_5822829_n
Test fitting =) 18543_406804850712_695975712_10507455_6226773_n
Test fitting =) 18543_406806770712_695975712_10507483_2664949_n
Test fitting =) 18543_406806775712_695975712_10507484_1730403_n
Last edited by boosted russian on January 6th 2010, 4:15 am; edited 1 time in total
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 5th 2010, 9:03 pm
Z?
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 5th 2010, 9:04 pm
Sure looks like it???
boosted russian
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 6th 2010, 4:02 am
Yeap, its a z,use to be chris's car from garage kwai.
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 6th 2010, 8:26 am
gross
Number of posts : 192
Vehicle : my endless moneypit s13
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 6th 2010, 2:21 pm
Sad your an asshole
boosted russian
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 6th 2010, 3:18 pm
haha. Whos an asshole?
boosted russian
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 9th 2010, 11:21 am
Started the wiring, I was going to have the car painted then put it together, buti its cold so I am going to finish everything then pull it out for when I paint it.
Building a new harness completely for the body and motor.
Test fitting =) 18543_413648740712_695975712_10572034_3284915_n
Test fitting =) 18543_413648745712_695975712_10572035_870042_n
The oil feed line is running a 12mm banjo to -4. I used this fitting and install ed the oil pressure sender. For the coolant line I used a 14mm x 1.5 to 1/8 npt. Only thing is the coolant temp sender sits about 2" from the peakboost manifold. I'll see if the temps are normal if not, Il relocated it.
Test fitting =) 18543_413648765712_695975712_10572037_4331280_nTest fitting =) Atm-2276_w
Test fitting =) 18543_413648755712_695975712_10572036_3742285_n
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 11th 2010, 10:28 pm
Allow me to relocate you.
nicoclub.com
Have fun. Dont bother sending a postcard.
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 12:05 am
boosted russian wrote:
Test fitting =)
I hate those damn smiley things.
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 12:20 am
It makes guys looks like virgins when they use it.
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 1:23 am
boosted russian
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 8:22 am
nicoclub.com
Why the hostility?
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 10:18 am
because of the --------> =)
internet lingo pshh
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 12th 2010, 12:20 pm
I love this forum.
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 23rd 2010, 8:23 am
cool car bro, any updates?
boosted russian
PostSubject: Re: Test fitting =)   Test fitting =) Icon_minitimeJanuary 30th 2010, 3:44 am
Yeap got a couple, nothing major. I was running my fuel lines and ran out of braided line. I didnt expect 20ft to barely be nough for the feed onliy. So Im waiting on fuel lines from JEGS.
I made a bracket that bolts to the firewall that has two bulkhead fittings. I was going to run the fuel lines straight from the cell to FPR and Rail, but I thoght it would be a good idea for it to be able to disconnect somwhere for whatever reason.
Also made a bracket for FPR.
After the lines are run, all I have to do is i/c piping for it to start up. Then brake upgrade and redo the brake lines for it to drive. After I will take it all apart and start preppinig it for the paint/cage install.
It was my first time working with AN fittings.
Test fitting =) 20743_450300120712_695975712_10832055_6255965_n
Test fitting =) 20743_450300150712_695975712_10832059_1435221_n
Test fitting =) 20743_450300130712_695975712_10832056_1191020_n
Test fitting =) 20743_450300135712_695975712_10832057_2921844_n
Test fitting =) 20743_450300145712_695975712_10832058_3651307_n
Test fitting =)
» Canoe & Kayak Drysuit Comparison Test
» Kid born to be a sports star? Take genetic test.
» Where to test a new GPX5000
» Kiteworld test on the Fluid ATV
» Virginity Test Kit
