| ka swap to ka HELp | |
+7KappS14 ka24orce 240nut D*S Dave Stab Master Sharson Curtis DeAngelo Nelson II bks14 11 posters |
bks14 Fucking Noob
Number of posts : 24 Age : 33 Location : summit Vehicle : 1996 240sx s14 Reputation : -2
| Subject: ka swap to ka HELp November 2nd 2009, 7:55 pm | |
| i have swap mi 96 ka motor for a 97 or 98 motor not sure but just wondering was i suppose to swap the ecu too??? i need help or else i cant pass emission | |
Number of posts : 768 Age : 34 Location : WAY north Chi-town, Illinois Vehicle : dirty girls Reputation : 3
| Subject: Re: ka swap to ka HELp November 2nd 2009, 10:18 pm | |
| Subject: Re: ka swap to ka HELp November 3rd 2009, 10:45 am | |
| ecu's should be the same unless one is automatic and the other isnt. the auto doesnt have a limiter but can still be used on with the 5 speed. | |
| Subject: Re: ka swap to ka HELp November 3rd 2009, 12:44 pm | |
| Yup. The coon is right. I have an auto ecu in mine. No cel or anything like that. Your straight. | |
240nut Forum Frequenter
Number of posts : 259 Age : 37 Location : Norridge, IL Vehicle : 1995 240sx Se Reputation : -3
| Subject: Re: ka swap to ka HELp November 3rd 2009, 2:19 pm | |
| you guys are right i have auto ecu still after my 5 speed swap. i have a 5 speed ecu but to lazy to put it in.... only thing my car does is it keeps dying out when you cold start it if you dont give it a little gas. other than that no cels. | |
ka24orce Ace Combat Driver
Number of posts : 372 Age : 40 Location : Riverside Vehicle : 180sx, Reputation : 11
| Subject: Re: ka swap to ka HELp November 3rd 2009, 3:30 pm | |
| 96 is different ecu than 97 | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp November 8th 2009, 1:37 pm | |
| - ka24orce wrote:
- 96 is different ecu than 97
so i should change the ecu to a 97????? | |
| Subject: Re: ka swap to ka HELp November 9th 2009, 9:28 am | |
| check Jim Wolf website. They have instructions on what wires to change. U can keep that ecu but gotta switch some wires around | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp November 10th 2009, 3:06 pm | |
| - ka24orce wrote:
- check Jim Wolf website. They have instructions on what wires to change. U can keep that ecu but gotta switch some wires around
wats his web site.... thanks for the help | |
KappS14 Light Duty Poster
Number of posts : 126 Age : 33 Location : Schaumburg Vehicle : 91 240sx HB Reputation : 1
| Subject: Re: ka swap to ka HELp November 11th 2009, 2:00 pm | |
| Subject: Re: ka swap to ka HELp December 6th 2009, 12:52 pm | |
| Did you ever figure this out?
95 , 96, 97 and 98 all had different ECUs. However the engines 96+ should be the same having OBDII emissions components. I would run the ECU from your car and the wiring from your car on the new motor. The ECU year and engine harness should match the cars year.
Plugs and sensors should all be the same. 95s dont have OBDII so there is less crap under the hood. Also 95 ECUs are the only ones that can be chipped for real time ROM tuning. Well as far as S14s are concerned, S13 DOHC ecus all can do that. | |
bks14 Fucking Noob
JakeS14 Forum Frequenter
Number of posts : 486 Age : 34 Location : Chicago Vehicle : 97 240sx Reputation : -1
| Subject: Re: ka swap to ka HELp December 14th 2009, 4:21 pm | |
| might not pass if its a straight pipe, but I have a header with 3"cat back and it passes
either way if you have a straight pipe they make plugs for where the senor goes into and it should pass
And check you air intake temp sensor, check if the wires been cut or if theres no sensor at all your car will fail emissions- happened to me | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp December 17th 2009, 9:21 pm | |
| na man i aint got straight pipe i got the gay ass hi flow from top speed....but ill do all those check thanks for the help! | |
| Subject: Re: ka swap to ka HELp December 17th 2009, 9:22 pm | |
| This is why I love my 1995 =) | |
| Subject: Re: ka swap to ka HELp December 18th 2009, 10:16 pm | |
| HAHHA so do I ! I got my 95, but is your car throwing a check engine or what? There is a secondary 02 sensor after the cat, you need that hooked up and reading for emissions purposes otherwise you will not pass. | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp December 23rd 2009, 7:12 pm | |
| - ChicagoS14T wrote:
- HAHHA so do I ! I got my 95, but is your car throwing a check engine or what? There is a secondary 02 sensor after the cat, you need that hooked up and reading for emissions purposes otherwise you will not pass.
dude i replace both o2 and i got mi pcv valve and charcole canister replaced idk wat else to do | |
| Subject: Re: ka swap to ka HELp December 26th 2009, 5:54 am | |
| You can always bring it by my shop and we can diagnose it. Its hard to say what it is without taking a look at the car. We can go over it for free we dont charge for inspection.
hit me up: 773-391-4313 | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp December 28th 2009, 9:40 pm | |
- You can always bring it by my shop and we can diagnose it. Its hard to say what it is without taking a look at the car. We can go over it for free we dont charge for inspection.
hit me up: 773-391-4313 for sure man thanks for the help ill hit u up | |
| THAT SHITS POSSESED BRO CALL THE PRIEST | |
bks14 Fucking Noob
| Subject: Re: ka swap to ka HELp January 3rd 2010, 7:47 pm | |
| - Death*Star wrote:
- THAT SHITS POSSESED BRO CALL THE PRIEST
i no i do u no of one so it can take the demon out so i can put a turbo charged angle in it lol | |
| Subject: Re: ka swap to ka HELp | |
