| need help again, ASAP!!! | |
+5D*S Dave Nachtmensch D*S Roski gOtPUrPL3 scubasteve 9 posters |
scubasteve Light Duty Poster
Number of posts : 148 Age : 37 Location : Chicago, IL Vehicle : 92 Nissan 240sx Reputation : 0
| Subject: need help again, ASAP!!! June 11th 2009, 9:32 pm | |
| I found that my starter was cracked and broke . I went out and bought another, installed it . Now my car won't start, my lights and everything else comes on . Also the car will jump start and run but won't start with the key . I need help ASAP, please any ideas(useful ideas) welcome. THANKS!!! | |
gOtPUrPL3 Post Enthusiast
| Subject: Re: need help again, ASAP!!! June 11th 2009, 9:35 pm | |
| Subject: Re: need help again, ASAP!!! June 11th 2009, 9:38 pm | |
| Battery is fully charged. | |
| Subject: Re: need help again, ASAP!!! June 11th 2009, 9:52 pm | |
| try a battery you know works because thats the only thing it could be if it starts from a jump | |
| Subject: Re: need help again, ASAP!!! June 11th 2009, 9:58 pm | |
| Subject: Re: need help again, ASAP!!! June 12th 2009, 1:15 pm | |
| I just bought a new battery and nothing. A waste of money and time... | |
D*S Roski DS! DS! DS!
| Subject: Re: need help again, ASAP!!! June 12th 2009, 6:32 pm | |
| AHahAhahaHaHa
dabs GOT YOU GOOD!
hahahaha | |
| Subject: Re: need help again, ASAP!!! June 12th 2009, 8:31 pm | |
| by jump start you mean jumping it from another car right or are you just saying the car dont start with the key im confused if it was infront of me i would know the problem.more details | |
| Subject: Re: need help again, ASAP!!! June 12th 2009, 9:03 pm | |
| Jumping it with cables it does the same thing as if I was useing the keys, NOTHING. If have PUSH START it, my car runs and drives. | |
| Subject: Re: need help again, ASAP!!! June 12th 2009, 10:35 pm | |
| Does the starter have the power cable from the battery? Signal wire sending the signal to crank? have a good ground on your motor (grounding out the starter)?
thats all it needs... | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 12:48 am | |
| ^^^ yea i thought you were jumping it off another battery you should have said push start | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 1:53 am | |
| i had a similar problem... check your ignition fuse that is in the fuse box on your engine bay.... 5 bucks says its that... | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 11:03 am | |
| - Nachtmensch wrote:
- Does the starter have the power cable from the battery? Signal wire sending the signal to crank? have a good ground on your motor (grounding out the starter)?
thats all it needs... thanks I'll check that it out. | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 11:04 am | |
| - eckominds wrote:
- i had a similar problem... check your ignition fuse that is in the fuse box on your engine bay.... 5 bucks says its that...
Thanks I'll check that too. | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 7:19 pm | |
U owe me five bucks, it's not my fuse... | |
Xmax Established Member
Number of posts : 593 Age : 42 Location : CaRoL sTrEaM Vehicle : 1993 S13 Fastback and 2006 Mazdaspeed 6 Reputation : 0
| Subject: Re: need help again, ASAP!!! June 13th 2009, 7:48 pm | |
| Check the ignition switch, this requires taking the lower have of your steering column out. | |
| Subject: Re: need help again, ASAP!!! June 13th 2009, 7:50 pm | |
| - Xmax wrote:
- Check the ignition switch, this requires taking the lower have of your steering column out.
Wut am I looking for? When I put the key in and turn it to start my dash lights(e-break, seatbelt,etc) comes on. | |
Number of posts : 355 Age : 112 Location : North Riverside under the mall Vehicle : 1991 240sx fastback sr20det part 2 Reputation : 12
| Subject: Re: need help again, ASAP!!! June 14th 2009, 12:40 am | |
| Check the lines to your starter for juice. | |
| Subject: Re: need help again, ASAP!!! June 14th 2009, 3:02 am | |
| - scubasteve wrote:
U owe me five bucks, it's not my fuse... edit: im a dumbass for not reading what i posted. lol
JAYYS Light Duty Poster
Number of posts : 140 Age : 35 Reputation : -1
| Subject: Re: need help again, ASAP!!! June 14th 2009, 3:12 am | |
| - scubasteve wrote:
Thanks I'll check that too. u didn't cheak that before u posted 2 thing to cheack alternator fuse and go over everything u touched u said this happened after a starter change? | |
| Subject: Re: need help again, ASAP!!! June 14th 2009, 11:49 am | |
| Subject: Re: need help again, ASAP!!! June 14th 2009, 12:59 pm | |
| is you starter signal wire plugged into the starter.there should be a power a ground and the signal wire on the starter | |
| Subject: Re: need help again, ASAP!!! June 15th 2009, 2:04 pm | |
| Thank you guys for all your help, this has been a real pain. The starter I bought was defected, so I returned it and got another. Fucking Autozone (loser)... | |
demian112 Forum Frequenter
Number of posts : 494 Age : 34 Location : joliet, Illinois Vehicle : 1992 240sx vert Reputation : 3
| Subject: Re: need help again, ASAP!!! June 15th 2009, 8:22 pm | |
| Subject: Re: need help again, ASAP!!! | |
