 Mr.K's beginning 89' hatch
Go to page : Previous  1, 2, 3, 4, 5, 6  Next
Number of posts : 486
Vehicle : 97 240sx
Mr.K's beginning 89' hatch - Page 4 Empty
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 10th 2009, 2:58 pm
You can always hit up dudes from TF on AIM if you have questions
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 10th 2009, 3:31 pm
I do plan on buying most of my stuff there. lol first time i went i couldnt find it because it was so small and it said something about logistics on the building
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 10th 2009, 4:23 pm
You should have called me.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 10th 2009, 6:04 pm
yeah should of. but i dont have your number.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 13th 2009, 1:22 am
so yeah an update.
i just replaced two bad fuel injectors yesterday and the car is till running like shit. two cyl still.
did a compression test and the two cyl in the middle barely have compression at all. tried adding some oil in the spark plug tubes and got better numbers. now i know i need new rings.
so this sucks. i think i am going to need help. only rebuilt an engine in engines class, so i have an idea. but if anyone has any words of advice. let me know.
does anyone have a cherry picker to lend?
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 13th 2009, 1:25 am
oil in the spark plug tubes?
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 13th 2009, 1:29 am
yeah to see if it fills in the gap between the rings. if it holds and then compression is up. that means the rings are worn.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 13th 2009, 1:30 am
what kind of numbers are you getting? do a leak down test?
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 13th 2009, 1:43 am
kinda forgot the numbers. around 130ish on 1 and 4. less then 110 in 2 and 3. ill have to test again tomorrow for accurate numbs.
i forgot about a leak down test. but i dont know anywhere to rent out the gauge. i dont have a compressor either.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 15th 2009, 2:23 am
130 and 110? I know they're not exactly the same but I dunno if thats bad enough to have to do a rebuild.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 15th 2009, 4:02 pm
still this a very old engine an from these numbers its pretty worn. im going to start getting shit ready for engine removal today.
Does anyone have a hoist I can rent or borrow from?
ill do you a favor in exchange too.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 15th 2009, 10:06 pm
KA? idk nt really following this thread. but ur compression #'s should be around 170-160. thats pretty bad if ur #'s are accurate.
autozone rents out compression gauges too.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 15th 2009, 11:13 pm
Yeah my numbers are really low compared to spec.
i know that my rings are the issue because cyl 2 n 3 are not holding enough compression to create ignition. I have fuel fouled plugs and the intake and exhaust manifold have fuel in the ports. I also made sure it wasnt the plugs because i switched out plugs from the other cylinders. and still same shit.
I have spark.
so rebuilding the engine is now on the agenda.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 15th 2009, 11:14 pm
oh yeah its a KA single cam
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 23rd 2009, 10:06 pm
OK THIS IS AN UPDATE!
I just finished taking out the engine just 20 mins ago.
It wasnt as hard as i thought it would be. This was my first time taking an
engine out btw and i am pretty happy with how things turned out.
Here are some pics and i have been doing a lot of thinking.
I am really considering going KA-T. I did some research and potential power is decent to what im looking for since im a novice driver anyway.
Right now im focusing all my attention on suspension set up and a dependable motor/trans. Will be getting the engine checked out within the following weeks and if all is well, rebuild is inevitable.
Mr.K's beginning 89' hatch - Page 4 101_0197
Mr.K's beginning 89' hatch - Page 4 101_0198
Mr.K's beginning 89' hatch - Page 4 101_0199
Mr.K's beginning 89' hatch - Page 4 101_0201
Mr.K's beginning 89' hatch - Page 4 101_0200.
hmm pics came out shitty...oh well ill fix it later.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 23rd 2009, 10:17 pm
so ur gonna rebuild a single cam ka and turbo it?
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 23rd 2009, 10:54 pm
Yeah thats the plan. Its affordable power.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeApril 23rd 2009, 10:55 pm
but i dont plan on doing it RIGHT away or anything. when I get comfortable enough driving and get more skills
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 8:54 pm
Ok so you guys know I'm rebuilding my engine. I have to take the head of and see what size rings I will be needing. In the meanwhile I recently got my coils in and here are the progress pics so far.
Trans and engine separated. Had hard time with the intake manifold. didnt know the the upper plenum had to come off.
Mr.K's beginning 89' hatch - Page 4 101_0218
Mr.K's beginning 89' hatch - Page 4 101_0221
I notice this when I was doing the coils. Ehh it's fixable.
Mr.K's beginning 89' hatch - Page 4 101_0207
I know you guys have seen stances a million times. But they are a Huge difference.
Mr.K's beginning 89' hatch - Page 4 101_0206
Mr.K's beginning 89' hatch - Page 4 101_0208
Mr.K's beginning 89' hatch - Page 4 101_0210
After i put em on. i just did the right side. i was being lazy so ill get to the other side when im ready.
Mr.K's beginning 89' hatch - Page 4 101_0211
Mr.K's beginning 89' hatch - Page 4 101_0212
Test fitting, needs to be lower. Im going to slam it all the way.lol
Mr.K's beginning 89' hatch - Page 4 101_0223
So thats progress so far. estimated completion date. Junish.
to get it running i Still need:
rings
welded diff
weld the fender well
electric fan
misc. hoses and gaskets.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 8:59 pm
relocate your harness before you "slam" it. you can thank me later or after your done fixing your chewed up harness ill be laughing telling you, "i told you so".
btw. those tires LOOK fucking hugemungo bungo!
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 9:05 pm
i never knew coilovers could sit so high.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 9:14 pm
go lower. collars should all be touching. preferably, remove some collars.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 9:42 pm
On 15's just max them down to where all the collars are still on but all touching. Max low in the back.
Text me if you have any questions.
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 4th 2009, 11:09 pm
yea you need to actually lower that
PostSubject: Re: Mr.K's beginning 89' hatch   Mr.K's beginning 89' hatch - Page 4 Icon_minitimeMay 5th 2009, 8:30 am
Yeah i really do need to go lower. I was just testing them out, so ill take the advice and make all the collars touch.
I will have to relocate the harness in the fender? didnt know that,good thing ecko told me that or I wouldn't have done it.
Progress is slow but coming along pretty well.
Edgar I will need your expertise when im ready for wheel fitment. I loved what you had with the your red ssr's...HOT!
Thanks for the input guys more updates will come.
Page 4 of 6Go to page : Previous  1, 2, 3, 4, 5, 6  Next
» 2007 Suzuki Sx4 Hatch!
» Grannom & Hawthorn Fly Alert
» Top 5 Vegetables Starting With the Letter "C"
» The beginning of a musical journey......
» Is this the beginning of the end for Toby Flood?
