| 180SX Kouki Side Skirt Install Question | |
SilEddy Light Duty Poster
Number of posts : 134 Age : 45 Location : Chicago Vehicle : 1992 Nissan 240SX SE Reputation : 2
| Subject: 180SX Kouki Side Skirt Install Question March 15th 2009, 11:08 pm | |
| I will be receiving my set of OEM 180SX Kouki Side skirts soon and had a quick question for anyone who may have installed them before. The tabs along the bottom of the skirts, I assume are there for mounting but how are they supposed to be installed? I guess the quick way would be self tapping screws. Anyone know if there is any hardware available for an actual factory install? Any information would be helpful, thanks. Here are a couple pics for reference... | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 15th 2009, 11:33 pm | |
| Dont know about factory install
I used washers with self tapping screws. I also put down a strip of 3M two sided tape on the top section of the side skirts (its hard to miss, there is a small section where the tape fits perfectly) | |
JakeS14 Forum Frequenter
Number of posts : 486 Age : 34 Location : Chicago Vehicle : 97 240sx Reputation : -1
| Subject: Re: 180SX Kouki Side Skirt Install Question March 16th 2009, 12:03 am | |
| - Dirty Dee wrote:
- Dont know about factory install
I used washers with self tapping screws. I also put down a strip of 3M two sided tape on the top section of the side skirts (its hard to miss, there is a small section where the tape fits perfectly) Exactly what im doing with my oem s14 kouki sides. Using the two sided 3m tape on the top portion for support. Dont know if i drill holes myself, or have a body shop do it(a lot easier when its on a lift). The guy i talked to around my neighborhood would charge 50 bucks a side. SilEddy- I would try going with a body shop, it might be too much a hassle to get up underneath ur car and line up the holes in the side skirts to where u are going to drill. I was thinking about making some sort of template but idk just a bitch using jacks imo | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 16th 2009, 12:16 am | |
| its not that hard
I did it by myself. Just jack up the side of the car so you can fit the drill motor underneath | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 16th 2009, 12:22 am | |
| ^True dat The main reason im taking mine to a shop is because i dont have time between now and the first meet. College Midterms are the problem Haha bullshit holdin me back, haven't even washed my damn car in all this nice weather ..... | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 16th 2009, 6:03 pm | |
| Since I work @ a shop I can put it on a lift to do the install, I think I'll go with the 3m tape and self tap screw idea. we use 3m tape for out Honda Aero parts installations and self tapping screws just made sense. Thanks for the info. If anyone does know of a factory install procedure please let me know. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 18th 2009, 12:48 am | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 18th 2009, 11:56 am | |
| Naw, i decided to do it myself yesterday. Turned out great | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 19th 2009, 6:04 pm | |
| OK, I opened the boxes and it seems like since they are brand new, they come with some clips and some tape already, at least the front fender pieces. didnt get to open the longer rocker panel piece before the painters took it but we'll see tomorrow when I get them back. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 19th 2009, 6:27 pm | |
| the side skirts should come with some metal clip that attaches to the pinch weld. Helps keep the skirt snug against the body. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 19th 2009, 6:33 pm | |
| - Dirty Dee wrote:
- the side skirts should come with some metal clip that attaches to the pinch weld. Helps keep the skirt snug against the body.
Sweet, thanks for the info. I'm gonna try to bribe one of my techs to install it for me since I'll be on the clock. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 25th 2009, 1:29 am | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 26th 2009, 11:32 pm | |
| ok for the mystery clip the needed grommet is this one. part number is 76848-71S00. you'll need 18 for the smaller one, its common grommet also used on the outer b-pillar trim part number is 76848-35F00. you'll need 4 hope this info helps anyone looking to install factory 180 kouki skirts. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 27th 2009, 12:08 am | |
| I installed factory kouki skirts. Didnt need them. You know you are going to have to tap holes into the body in order to use all of those random clips right? | |
| Subject: Re: 180SX Kouki Side Skirt Install Question March 27th 2009, 9:43 pm | |
| - Dirty Dee wrote:
- I installed factory kouki skirts. Didnt need them. You know you are going to have to tap holes into the body in order to use all of those random clips right?
yes, but i want to get as close to oem as possible. and if some accident were to happen I'd like the clips to pop out of the grommet as they are supposed to instead of breaking in the body or doing damage to the body. also, no other hardware is provided and aside from just tape to prevent sag i'd like to do it right. thanks for the input though. | |
| Subject: Re: 180SX Kouki Side Skirt Install Question | |
