| Remove Seats From An S14 | |
+4Jay FusionR300zx Nachtmensch dabears_23 8 posters |
dabears_23 Fucking Noob
Number of posts : 53 Age : 33 Location : Cicero/Champaign Vehicle : 98 S14 LE Reputation : 0
| Subject: Remove Seats From An S14 January 20th 2009, 12:21 am | |
| I just bought a 98 240sx LE but the leather seats are dirty, and all torn up.
I have a 95 240sx Base that has perfect seats.
I basically wanna swap seats between the cars, front and rear.
How do i go about removing the seats from the cars. Do i remove the rails from the front? Any help would be appreciated.
Thanks in advance. | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 12:29 am | |
| 4 bolts per front seat and a connector for the seatbelt sensor. those are super easy. all cars are like that.
rears require you to fold them down and take the top section off first. i think they had clips on the sides that had to be undone (where the top hinges). from there, it should be one 10mm bolt holding the bottom in. lift the rear, and work it out. you'll see the guides in the front.
i dont recall on the s14s, but i think they might have had some pull taps to get the front loose. this is all from memory from s14 seats from like 2 years ago. so it might not be exact. just look around and remove bolts that look like they might hold the seats in. | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 12:44 am | |
| - Nachtmensch wrote:
- 4 bolts per front seat and a connector for the seatbelt sensor. those are super easy. all cars are like that.
i dont recall on the s14s, but i think they might have had some pull taps to get the front loose. this is all from memory from s14 seats from like 2 years ago. so it might not be exact. just look around and remove bolts that look like they might hold the seats in. thanks a bunch, ill try it tommorow | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 6:16 am | |
| 4 bolts pull em out. for fronts. rears fold down. 2 bolts each side on the tab that folds. then 2 bolts on the bottom. slip the seat belts thru the bottom cushion.
prolly coulda figured it out on your own cuz it's so easy. | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 9:44 am | |
| - FusionR300zx wrote:
- 4 bolts pull em out. for fronts.
prolly coulda figured it out on your own cuz it's so easy. I doubt it. He'll probably will need a write-up about it. with picturez! | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 3:01 pm | |
with picturez! NICO probably has that for their "special" users | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 3:51 pm | |
with picturez! NICO probably has that for their "special" ED users | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 4:33 pm | |
| Wow... wrong section + stupid question = hella Fail | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 5:23 pm | |
| hey guys, not wanting to threadjack, but how do replace the stock wheels with aftermarket onez??????
plz post step by step w/ pikz | |
SIMON Post Whore
| Subject: Re: Remove Seats From An S14 January 20th 2009, 6:06 pm | |
| i gotchu dee. | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 7:03 pm | |
| but my car has 5 lugs. what do i do after step 4? | |
| Subject: Re: Remove Seats From An S14 January 20th 2009, 7:06 pm | |
| - Dirty Dee wrote:
- hey guys, not wanting to threadjack, but how do replace the stock wheels with aftermarket onez??????
plz post step by step w/ pikz i havent gotten that far yet. ill make sure to do a write up when the time comes | |
chitown240SX Light Duty Poster
Number of posts : 192 Age : 42 Location : Chicago Vehicle : S14 Reputation : 0
| Subject: Re: Remove Seats From An S14 | |
