| Building all the wrong cars | |
+70Matej JohnnyDrift David fresheg6 Vegas13 Cyclohexyl Coupe sleepyeyed240 ill roller ferrarisx D*S Homeboy. YELLOW D*S Tomy Guns danstel456 Trucky's bitch. AMD 240 blklabel44 Adrian_S13 240slider8 shiftin_sideways zero RacerX evanger drftx s14rob s13 brian Curtis DeAngelo Nelson II LeMoine gOtPUrPL3 Xmax koukimonster 240nut 007 Scuba Steve 14k s14 mrkan mikemadison_09 k c djexpo energ hs13kls JAYYS Dirty Dee Los Vlados Locos D*S Dave his180sx Mr.BackFire Jay splitime D*S Roski JakeS14 rcl1221 Nackers danielekfuj FusionR300zx SIMON timmuh SylviaFan Flicktitty ilia Stab Master Sharson DJ Longdick whiterps13 RAD MIKE Circa 3006 D*S Dstar RAMM D*S Trucky sad REVGASM Specter Nachtmensch 74 posters |
| Subject: Re: Building all the wrong cars March 20th 2011, 4:31 pm | |
| You make it sound like a bad thing...? | |
fresheg6 Light Duty Poster
Number of posts : 177 Age : 34 Location : bourbonnais,il Vehicle : 91 s13 Reputation : 0
| Subject: Re: Building all the wrong cars March 20th 2011, 4:54 pm | |
| so does that mean you will make 235 on the high lobe. | |
| Subject: Re: Building all the wrong cars March 20th 2011, 11:12 pm | |
| It means I'm confused why my numbers are that much higher. Oh well... | |
| Subject: Re: Building all the wrong cars March 21st 2011, 5:42 pm | |
| dynos off/read differently | |
| Subject: Re: Building all the wrong cars March 21st 2011, 6:03 pm | |
| Our dyno made 121 on the 1zz I had, which is about 10% lower than a Mustang dyno I ran on with the same setup. The 1zz numbers sound right for this dyno. Dyno Dymanics (what we have) is known to be one of the lowest reading dynos. Someone making 25hp less than me is quite a bit less. Most 2zz's dyno on a Dynojet, a higher reading dyno. | |
D*S Homeboy. DS! DS! DS!
Number of posts : 876 Age : 39 Reputation : 6
| Subject: Re: Building all the wrong cars March 21st 2011, 11:05 pm | |
| Sooo.....is this shit fast or whaaa? | |
| Subject: Re: Building all the wrong cars March 21st 2011, 11:56 pm | |
| it's quick for sure. not boosted up evo fast though. plenty of power to have fun. sounds real cool too. | |
JohnnyDrift Fucking Noob
Number of posts : 7 Age : 32 Reputation : 0
| Subject: Re: Building all the wrong cars March 31st 2011, 3:52 pm | |
| Really dope car, I want one. | |
| Subject: Re: Building all the wrong cars April 8th 2011, 9:40 pm | |
| Got some toe rods, since the passenger's side was bent. Then lowered the car some more. Also realized my passenger's side CV boot is leaking again.... They don't like being this low. Makes it the 4th boot to rip. | |
| Subject: Re: Building all the wrong cars April 8th 2011, 9:54 pm | |
| you might want to check to make sure it's not rubbing on something. what is the stock axle angle? cause unless it's flat, wouldn't it make no difference if it was 20* up or down off plain? | |
| Subject: Re: Building all the wrong cars April 8th 2011, 10:05 pm | |
| There's nothing to rub around there. It's coming off an intermediate shaft. Stock axle angle is relatively flat. hard to see, so I highlighted the axle angle | |
| Subject: Re: Building all the wrong cars April 9th 2011, 12:50 am | |
| Mine have been torn for like 2years now, and I stay clutch kicking!!!! | |
| Subject: Re: Building all the wrong cars April 9th 2011, 2:52 am | |
| ^That's my nigga right there!!! | |
YELLOW Post Enthusiast
Number of posts : 1444 Age : 35 Reputation : 7
| Subject: Re: Building all the wrong cars April 9th 2011, 9:21 am | |
| Subject: Re: Building all the wrong cars April 9th 2011, 8:08 pm | |
| Car feels way better with these and the "alignment" I did after a tape measure. | |
| Subject: Re: Building all the wrong cars April 9th 2011, 8:59 pm | |
| yeah, i saw the angle of the axle in the first pic, i guess i was going off of S13 shit, where the stock angle is pretty much the same, just the other way due to the stock 4x4 status.
idk, thicker CV boots? try seeing if honda ones might fit? cause ones build for axles that turn corners on a regular basis might hold up better to the increased angle you're now running. | |
| Subject: Re: Building all the wrong cars April 9th 2011, 10:55 pm | |
| boot repair kits are only $30 from Toyota. (boot, clamps, grease) The one that is ripped has 3 indents around the tripod joint, it's not a perfect circle. | |
| Subject: Re: Building all the wrong cars April 10th 2011, 10:58 am | |
| Subject: Re: Building all the wrong cars April 14th 2011, 12:08 pm | |
| You should get that fitment on point, tuck and roll baby!!!! | |
| Subject: Re: Building all the wrong cars April 14th 2011, 11:07 pm | |
AMD 240 Established Member
Number of posts : 667 Age : 36 Location : Glendale Heights IL Vehicle : 90 coupe Reputation : 3
| Subject: Re: Building all the wrong cars April 14th 2011, 11:15 pm | |
| ffffffffffuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuuu | |
| Subject: Re: Building all the wrong cars April 14th 2011, 11:19 pm | |
| Now me and the mad scientist got to rip apart the block...
| Subject: Re: Building all the wrong cars April 14th 2011, 11:53 pm | |
| Subject: Re: Building all the wrong cars April 14th 2011, 11:56 pm | |
| I was hauling ass off an on ramp making my way home. PFC knock detection shot up and blinked the CEL. Don't think the stock bottom end liked 9000rpm. Thinking about building the bottom end if the crank is salvageable. If it isn't, I may build up a different block. All depending on what I can afford. I want to make a few track events this year with it. | |
| Subject: Re: Building all the wrong cars April 15th 2011, 6:32 am | |
| Damn. Salty. Put your old motor in and get a diff
Now I know who not to go to for motor building. . . | |
| Subject: Re: Building all the wrong cars | |
