| helper spring ? | |
+2Stab Master Sharson dorikin717 6 posters |
dorikin717 Established Member
| Subject: helper spring ? June 23rd 2008, 9:03 pm | |
| hey i just want to know what the helper spring dose, and if they are removeable maby to go lower but i dont wanna mess anything up, i looked online and dident find any real awnsers so can i get some help ?? | |
| Subject: Re: helper spring ? June 23rd 2008, 9:17 pm | |
| u can take it out if u want..... its supposed to obsorb some of the impact before the bigger and much stiffer spring does..... itll make the ride stiffer, but ur not gonna die if u remove it. | |
| Subject: Re: helper spring ? June 24th 2008, 2:33 am | |
| do u think i can get any lower | |
| Subject: Re: helper spring ? June 24th 2008, 10:16 am | |
| - Stab Master Arson wrote:
- its supposed to obsorb some of the impact before the bigger and much stiffer spring does
actually no. if you want low - take it out. | |
| Subject: Re: helper spring ? June 24th 2008, 10:29 am | |
| I think the helper spring has something to do w/ preload | |
| Subject: Re: helper spring ? June 24th 2008, 11:33 am | |
| ok so my main question is will i be able to go lower if i remove it? | |
| Subject: Re: helper spring ? June 24th 2008, 12:42 pm | |
| Subject: Re: helper spring ? June 24th 2008, 2:56 pm | |
PacoX Light Duty Poster
Number of posts : 123 Age : 39 Reputation : 0
| Subject: Re: helper spring ? June 24th 2008, 5:22 pm | |
| If you remove it, you'll be able to get your car lower, as ^^^ said. If it's a true helper spring, the rate should be really low, and it's basically there to keep the main spring from flopping around under droop. If it's a tender spring, it will have a bit higher rate that actually contributes somewhat to the overall spring rate and can help get more usable droop travel. Here's an (incomplete) explanation I just googled: http://www.e30m3performance.com/tech_articles/susp-tech/springs/index.htm | |
| Subject: Re: helper spring ? June 24th 2008, 11:17 pm | |
| ok i see i just dont wanna termanily damage the coilovers, so i should be ok if theyare removed? | |
| Subject: Re: helper spring ? June 24th 2008, 11:55 pm | |
| people told you 4 times already
you can't be too bright.
why don't you ask it few more times. | |
| Subject: Re: helper spring ? June 25th 2008, 12:17 pm | |
| Subject: Re: helper spring ? | |
| helper spring ? | |
