PacoX Light Duty Poster
Number of posts : 123 Age : 39 Reputation : 0
| Subject: S14/KA/SR stuff FS June 2nd 2008, 9:13 am | |
| I just picked up an SR with some extra parts I won't be using. The previous owner installed the stuff and turned it over, but never got his harness figured out so there was no spark and thus, the motor never ran. So, parts designated new/used are things that he bolted up but didn't actually run the motor with. Other things are just stock SR parts from the motor, or other parts I have laying around from a previous setup. If interested, please email me at rrozyck@gmail.com for the quickest response. I'm located near Pilsen/UIC. TurboFab mani/dp/dumptube: Top mount log manifold for SR20DET, comes with dumptube and downpipe. Wastegate flange is Tial 38mm pattern; downpipe has had the 5 bolt flange chopped off and a 4 bolt GT style flange welded on. This setup was supposed to go on a Nissan Frontier, and I believe that's what the downpipe should fit now. You could probably modify the DP to fit on a 240 though, as it doesn't look much different from the pics of the DP online, other than the 4 bolt flange. $250SR 370cc injectors: Purple, plastic is a little chewed up from removal but they should work fine, $80T25 discharge elbow: $15S13 SR A/C compressor: Includes bracket. $50S13 SR turbo oil/coolant hardlines: Um, make offer S13 SR clutch & flywheel: Stock parts, make offer Saga boost gauge: 60mm Saga 2.0 Series (warning function, but no recording), reads in PSI, amber lighting, used but in nice shape, comes with stand $100JWT C1 cams: S13 SR cams, new/used (=bolted on, never run), $450Mocal thermostatic sandwich plate: 3/4"-16, I believe this fits S13 SR, KA, and RB (pretty sure S14/S15 SR are the only ones that are different), (2) 1/2" NPT ports to plumb an oil cooler, used, $652 used 235/40/17 Yoko ES100s: some inner shoulder wear, but overall decent tread left, should be fine for a long time if you run them with the worn side out- both for $60 Preview of parts soon to be for sale (SR stuff sooner, KA stuff later when I swap the car, coilovers who knows when, still waiting on my new rear setup): S14 KA24DE Hotshot header 95 S14 KA24DE and manual trans, ECU, A/C parts BC KA24DE 264/264 cams SR20DET Greddy valvesprings new/used SR20DET Greddy headgasket new/used S14 Stance GR+ coilovers with Z32 rear lower mounts
Scuba Steve Established Member
Number of posts : 551 Age : 35 Location : I don't know. It's really dark in here! Vehicle : '93 S13 with all the Fanboy features! Reputation : -7
| Subject: Re: S14/KA/SR stuff FS June 2nd 2008, 1:16 pm | |
| Would you be willing to sell the PS pump off the SR? | |
| Subject: Re: S14/KA/SR stuff FS June 2nd 2008, 2:08 pm | |
| Nope, I need that myself. This is pretty much it in terms of what I have for sale. | |
| Subject: Re: S14/KA/SR stuff FS June 23rd 2008, 10:11 pm | |
| How much for the BC cams? They are the V2s right? | |
dabears_23 Fucking Noob
Number of posts : 53 Age : 33 Location : Cicero/Champaign Vehicle : 98 S14 LE Reputation : 0
| Subject: Re: S14/KA/SR stuff FS June 24th 2008, 1:25 am | |
| how much for the 95 Man Trans and ECU? | |
| Subject: Re: S14/KA/SR stuff FS June 24th 2008, 5:11 pm | |
| $200 for the cams, yes, they are the BC V2 (264/264) cams.
$100 for the trans.
Neither is available yet though, as I said in that first post. Still have to swap the motor before that stuff is available. More of a heads up than anything...I'll hopefully have that stuff FS in a few weeks. | |
| Subject: Re: S14/KA/SR stuff FS June 24th 2008, 6:36 pm | |
| no extra ignitors at all? | |
lopez6558 Forum Frequenter
Number of posts : 321 Age : 36 Location : Schuamburg IL Vehicle : 95 240sx coupe/96 240sx coupe Reputation : 0
| Subject: Re: S14/KA/SR stuff FS June 24th 2008, 6:58 pm | |
| how much were you looking to get for the s14 stance coilovers | |
| Subject: Re: S14/KA/SR stuff FS June 26th 2008, 3:06 pm | |
| Nah, no extra ignitors, sorry.
Was thinking $750 for the Stances. They'll come with the extra set of springs (never used). I have the fronts off the car and they look pretty decent. I THINK the rears will be off in like a week and a half...I had no idea I'd be waiting this long for my new rear suspension. | |
| Subject: Re: S14/KA/SR stuff FS | |
