| Removing Oil Feed Line SR20DET Redtop | |
| Subject: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 2:29 am | |
| I was wondering what the easiest way of doing this is. I was considering removing the downpipe and unbolting the manifold and pulling it away from the head a bit to get a better angle on it, but I'd rather not do that if there is an easier way.
Thanks. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 2:44 am | |
| Use tools. Those make shit easier. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 6:14 am | |
| yank at it for awhile. it should come off if you keep at it. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 9:18 am | |
| its been a while, but isnt it just a banjo bolt? | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 12:03 pm | |
| Yea. I see it's a bit difficult to reach and was just wondering if anyone had found an easier solution to get at it. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 27th 2008, 2:04 pm | |
| well if you're taking off the turbo, yeah, just take off the mainfold to get access. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 28th 2008, 4:52 am | |
| Read what I posted Nackers. It should help you. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop May 28th 2008, 12:28 pm | |
| I did and it worked.
I didn't bother taking off the manifold. I just removed the hot pipe, intake, oil dip stick bolt, and wastegate actuator (a/c pump as well if you have it) and it was fairly easy. | |
| Subject: Re: Removing Oil Feed Line SR20DET Redtop | |
