 Fusion's Build/Mods/pics!
Go to page : Previous  1 ... 13 ... 22, 23, 24, 25, 26  Next
PostSubject: Re: Fusion's Build/Mods/pics!   May 20th 2011, 4:00 pm
I like 45 up front for tuckage and pan clearance. When I had 215/40 azenis in the front i was bashing pan on the reg.
PostSubject: Re: Fusion's Build/Mods/pics!   May 20th 2011, 9:00 pm
that's the only opinion i needed.
<3 u
PostSubject: Re: Fusion's Build/Mods/pics!   May 21st 2011, 12:18 pm
might have a hood for you
PostSubject: Re: Fusion's Build/Mods/pics!   May 21st 2011, 12:21 pm
i too have a hood for u.
PostSubject: Re: Fusion's Build/Mods/pics!   May 21st 2011, 2:08 pm
both of you send me pics please. =]
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 11:27 am
s13 front fenders are higher then the rears correct? i cannot tell, my car is floating on stands. just trying to get this setup done right, 17's all around, thinking of 45 series front, and 40 rear, as long as the front fenders are higher then the rear.
which i think they are.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 12:18 pm
I would do the opposite.
40 front 45 rear. or 45 all around.
40 rear would be squatting super hard. No thank you.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 12:20 pm
45 all around.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 1:58 pm
are those ebay tails with a tint lay over on them?
i know some1 on here has to remember that car.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 2:17 pm
Yes.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 3:16 pm
Blancos old car, t2 drives it now. And yessss I believe youre right.
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 11:22 pm
also, i'm a s13 noob. what rear is that? sexy style?
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 11:24 pm
VII
PostSubject: Re: Fusion's Build/Mods/pics!   May 24th 2011, 11:58 pm
aka "coming soon" the new knockoff from VS?
PostSubject: Re: Fusion's Build/Mods/pics!   May 25th 2011, 12:41 am
yoo, what size water temp adapt do s13's use? 34mm? can't seem to find it anywhere.. google searching for 2min, shouldn't take longer then 10 seconds to find if it was available.. gerr..
PostSubject: Re: Fusion's Build/Mods/pics!   May 25th 2011, 12:46 am
ebay altezza chromes clear lens tails, lens tint on inside of lens, then wetsanded.
PostSubject: Re: Fusion's Build/Mods/pics!   May 25th 2011, 12:58 am
From what I found, S14 KA was 34mm. So I assume S13 should be the same, but I haven't installed mine yet so I can't tell you if it's the right size or not.
PostSubject: Re: Fusion's Build/Mods/pics!   May 25th 2011, 1:11 am
its the same.
PostSubject: Re: Fusion's Build/Mods/pics!   May 25th 2011, 1:31 am
yea i remember my s14 being 34mm i believe. thanks for the info gentlemen. much appreciated.
PostSubject: Re: Fusion's Build/Mods/pics!   May 31st 2011, 8:57 pm
how do i go lower?
i feel like my s14 with megans went a lot lower then this.
i also feel like when i put 17x9.5 225/45 all around it will not be good/low enough, at all.
HALP.
2 collars off up front, 1 off on the rear, and the rear is as low is it will go.
i hear u can get shorter springs?
any other tricks to getting it lower then this.
PostSubject: Re: Fusion's Build/Mods/pics!   May 31st 2011, 10:44 pm
What coilovers?
PostSubject: Re: Fusion's Build/Mods/pics!   May 31st 2011, 10:49 pm
opps, thought it sounded clear when i referenced/compared em to my s14..
but it's on megan tracks.
PostSubject: Re: Fusion's Build/Mods/pics!   June 1st 2011, 8:07 pm
Thats what I got.
I removed all the collars all around, I know you could flip the mounts for more lowsauce!
PostSubject: Re: Fusion's Build/Mods/pics!   June 1st 2011, 9:14 pm
alright. what did u do for th rear? i have a collar removed and it wont spin up anymore and it's like 3mm from the next collar.
PostSubject: Re: Fusion's Build/Mods/pics!   June 7th 2011, 12:03 pm
alright... this is def not gona cut it.. the rear NEEDS to go like 1.5-2" lower. please help.
the front i think will be ok. still have the last collar on it and can flip the mount.
Page 23 of 26Go to page : Previous  1 ... 13 ... 22, 23, 24, 25, 26  Next
