| HELP TRUCK'Y!!!!!!!!!! | |
| Subject: HELP TRUCK'Y!!!!!!!!!! April 3rd 2008, 7:52 pm | |
| Ok so my SR still hasent ran, checked my ecm codes just incase and i got this code.... 55 - Other Malfunction. CONSULT Terminal Required
So does anybody know what it means cause im stumped???
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 3rd 2008, 8:09 pm | |
| you done fucked up.
does it crank, spark, fuel? | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 3rd 2008, 8:12 pm | |
| There is spark and there is fuel........but just doesnt start checked timing a million times and thats good, any ideas kevin....... | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 6th 2008, 11:16 am | |
| Come on dudes.......help me if you want to see my coupe at the meet.... | |
Number of posts : 355 Age : 112 Location : North Riverside under the mall Vehicle : 1991 240sx fastback sr20det part 2 Reputation : 12
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 6th 2008, 4:07 pm | |
| Check MAF wiring How far is MAF away from turbo? If this thing is wired wrong or in the wrong place it will give you the symptoms you describe.
Change MAF with someone here I just gave away the stock Sr maf that came with my engine or id tell you to pick it up.
Check CAS wiring
With the SR this problem on first start is almost always the CAS a slight adjustment
Also what does your injector wiring look like? I would suspect a problem there. Sorry there are just so many things i checked on mine after hours of searching. It wound up being a 1/2 inch adjusment to my CAS and then BROOOOOOM | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 6th 2008, 6:50 pm | |
| Well i havent checked the maf wiring and ill post pics of the injector wiring in a bit, but i think that cause of my problems is my cas, i cheked the voltage coming out of it and its suppose to be, 5v-0.1v and i get sparatic reading like up to 12v in just the second pin....also its like flooded all the time when i crank it and then remove the spark plugs, there is alot of fuel on them, but i checked for spark and there is spark.........so man i just plain dont know....if anyone can stop by and give a hand at starting it, ill gladlly pay for your services.....so just PM me..... | |
undesiredshoe Fucking Noob
Number of posts : 87 Age : 35 Location : Sheboygan, WI Vehicle : 240sx Reputation : 0
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 6th 2008, 11:58 pm | |
| Whats your maf voltage at?? | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 7th 2008, 12:03 am | |
| not sure, but i did this with my mr2 to find the circuit where there's a problem.
key to 'on' and test for power at the ECU at each pin using a paperclip from the backside of the connector and a multimeter. in my FSM it gave me what voltage each pin was suppoed to be at (either ON, cranking, or off)
but once again, im not sure if there is something like that for you. | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 8th 2008, 9:12 pm | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 8th 2008, 9:41 pm | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 10th 2008, 4:55 pm | |
| Not familiar with kazu, did they modify the ka harness or do the simple sr harness rewiring?
Anyway have you tested your ignitor chip and its wiring? | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 10th 2008, 5:24 pm | |
| yeah from everything ive seen for S13 to s13, it shouldve been super simple. | |
dwvinny Light Duty Poster
Number of posts : 116 Age : 46 Reputation : 0
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 10th 2008, 5:27 pm | |
| sounds like the code you got is bullshit check cas first if thats not it make sure theres not a broken or disconnected wire some where but if its cranking you got spark and fuel its either cas or compression problem ie not timed right ect did you have anything done internally on the motor?? | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! April 11th 2008, 11:45 pm | |
| Well i got spark, but my pump isnt starting now for some weird reason, but i put ground to it and it starts working, also just got another igniter, but i really think its my cas theres no other reason why it shouldnt start, im on a dead line my car is suppose to get painted in a week so it has to start, ill post the prosses that i used to test the cas in a bit....... | |
| Subject: Re: HELP TRUCK'Y!!!!!!!!!! | |
