| Blood Diamonds.... Part 1. | |
+83blklabel44 Cyclohexyl Coupe Trucky's bitch. YELLOW Olly ferrarisx D*S Homeboy. booey13 NismoDriftPunk altavelocidad Matej kpc_0721 mishkin_707 David ill roller AMD 240 xxcrashxx240 Fcknslo evanger skyvia686 ka24orce s13 brian RacerX silvia_s14 Curtis DeAngelo Nelson II sad timmuh s14rob JAYYS chitown240SX Los Vlados Locos energ They14s djexpo Specter Adrian_S13 SylviaFan whiterps13 silent knight JakeS14 his180sx splitime D*S Tomy Guns Mr.BackFire SIMON PacoX DJ Longdick LeMoine FusionR300zx ilia Lazer25 1998240sx rcl1221 g3t_sl1d3wayz D*S Dave RAD MIKE Circa 3006 jdmwackness mikey z Dirty Dee SPEEDTRIBE gOtPUrPL3 hs13kls k c Lsonboost flaps domdaaxe58 danielekfuj just Mike Scuba Steve SEXYDRIFTER REVGASM Jay Xmax NlineSicks240 Nackers 007 Stab Master Sharson tyler D*S Roski D*S Dstar 14k s14 Nachtmensch D*S Trucky 87 posters |
| Subject: Re: Blood Diamonds.... Part 1. December 14th 2008, 7:24 pm | |
| Yup, i know what u mean, i was just talking to Edgar and he said that SR's are the worst thing that we could have done to our cars...hopefully when take the head of its just a head gasket and nothing else, cause its not burning oil, its only mixing oil and coolant...
The good thing is that i have a place to put the coupe at while i fix the fastback....
This is seriously setting my build back, head's up guys i might be selling my silvia stuff soon.... | |
| Subject: Re: Blood Diamonds.... Part 1. December 14th 2008, 7:39 pm | |
| yea man, SR's are bittersweet. it just seems like everyone is having problems at the same time.
good luck with the build trucky!
meanwhile i'm trying to keep my cool stuff (body work and paint) on track, i DONT want this engine BS to set that back any farther. still planning on having all body work and paint finished by the time the weather is nice enough to drive it again. | |
PacoX Light Duty Poster
Number of posts : 123 Age : 39 Reputation : 0
| Subject: Re: Blood Diamonds.... Part 1. December 16th 2008, 12:11 pm | |
| Argh, fall 08 is death to SRs...sucks guys | |
| Subject: Re: Blood Diamonds.... Part 1. December 16th 2008, 1:17 pm | |
| - PacoX wrote:
- Argh, fall 08 is death to SRs...sucks guys
mine died back in 07 with a overboostin problem. NOTE TO EVERYONE.. NEVER USE A MBC!!!!!!!!!!!!! fuck em. | |
| Subject: Re: Blood Diamonds.... Part 1. December 16th 2008, 5:11 pm | |
fuck em. MBC for the win, im gonna build a sick ass baller car, and then get a MBC...shit's gonna be fire... | |
| Subject: Re: Blood Diamonds.... Part 1. December 16th 2008, 9:33 pm | |
| so you can be pushing 20lbs again? | |
| Subject: Re: Blood Diamonds.... Part 1. January 4th 2009, 11:17 pm | |
| Subject: Re: Blood Diamonds.... Part 1. January 10th 2009, 7:46 pm | |
| Allright well i removed the head, and the headgasket didnt seem damaged at all, i also realized that i had ARP head studs, dont know if the low compression on cylinder 2, was due to the head gasket, im at a hard decision, dont know if i should do the rings.. Since my reading was 120-60-120-120, and also since it was mixing coolant and oil... Kevin im looking in your direction for advice?? | |
| Subject: Re: Blood Diamonds.... Part 1. January 10th 2009, 7:53 pm | |
| did you retorque the ARP head studs after driving for 2-500 miles on them? i know they start to loosen initially and have to be torqued again. thats what happened with my 4age. i got lazy and figured "theyre fine." sure enough, they listed off and i had symptoms of a BHG again (coolant in water, white smoke, etc)
ill find the info from ARP on this. i had it somewhere.
Last edited by Nachtmensch on January 10th 2009, 9:08 pm; edited 1 time in total | |
| Subject: Re: Blood Diamonds.... Part 1. January 10th 2009, 8:10 pm | |
| when i pulled the 4age after the head lifted, some of the studs unscrewd by hand. from mr2oc - Quote :
- During the break-in period, the engine heat cycles, there are many vibrations that move things around, and other things that move the studs in the block. You have to re-torque the studs after this period, mainly to make sure the studs are seated in the block properly. If you do not, the head will eventually lift, and you'll get combustion gasses into the coolant system, overheating the car.
not sure on exact nissan arp use, but here's a overview - NoShoes wrote:
- I've been meaning to post this write-up for a while now. I've noticed over the years that MR2 enthusiasts do not take the time to retorque their ARP studs after engine break-in.
Here's what you do to keep this from happening:
1) Remove the valve cover.
2) Refer to the factory torque sequence (starting in the middle and working your way out in a criss-cross pattern just like you torque your wheels down), and work on one stud at a time. This torque sequence is shown below.
3) Break loose the first nut from the stud using a breaker bar.
4) Remove the nut completely. (A magnetic pick up tool works wonders!)
5) Use an allen key socket (A handheld tool just doesn't cut it here.) to bottom out the stud in the block.
6) Make sure the nut is cleaned, and liberally apply ARP moly lube (not oil, not multi purpose grease, but ARP moly lube) to the nut.
7) Torque the nut down to 65 ftlbs. (Not 70, not 75, but 65ftlbs)
Move to the next stud/nut combo in the torque sequence.
9) Repeat steps 3-8 in the correct torque sequence until you have done them all.
10) Clean the valve cover gasket mating surface with carb cleaner or brake cleaner. Use a razor blade to remove old silicone from the mating surface.
11) Apply a dab of Toyota FIPG (the black stuff) at each corner (where the semi-circle meets the flat surface of the head) of the 2 cam caps on the timing belt side, and the distributor shaft tunnel on the flywheel side. This will be 6 dabs of silicone total. (I have no idea how many times I have seen the valve cover installed without these dabs of silicone.) This is shown in the picture below.
12) Secure the valve cover with bolts or the 2SRUS allen key bolts using the factory grommets and you're good. Just DON'T use the stupid phillips head screws.
I hope this helps folks with rebuilt engines. If you do this properly, made sure your block and head were machined properly, and prevent detonation the best you can, you should not have a head gasket problem.
If you continue to have head gasket problems on a high horsepower car (usually when running race gas and lots of boost), I would suggest upgrading to L19 material head studs. These can be purchased from ATS Racing:
http://www.atsracing.net/ats_racing_L19_head_studs.htm
Happy motoring everyone! | |
gOtPUrPL3 Post Enthusiast
| Subject: Re: Blood Diamonds.... Part 1. January 10th 2009, 8:26 pm | |
| - Master Trucky wrote:
- Allright well i removed the head, and the headgasket didnt seem damaged at all, i also realized that i had ARP head studs, dont know if the low compression on cylinder 2, was due to the head gasket, im at a hard decision, dont know if i should do the rings..
Since my reading was 120-60-120-120, and also since it was mixing coolant and oil... Kevin im looking in your direction for advice?? it could be that the head lifted or there could be a crack in the head | |
| Subject: Re: Blood Diamonds.... Part 1. January 10th 2009, 9:13 pm | |
| Kevin when i removed the head, i was actually able to un-screw the studs with my hand. I had read about that but wasent to sure, im just going to put the head gasket back on and just re torque them.. Since they stole it before I even finished the 500m break in period, and i know they where beating the shit out of it..
Dabs im also going on monday to get the head resurfaced, and inspected, just to be sure... | |
| Subject: Re: Blood Diamonds.... Part 1. January 19th 2009, 5:51 pm | |
| Allright, since the head was in good condition, and the block had no signs of damage, i moved on to the piston. So when i removed it from the block, right away i realized that it had two cracks, but i just thought they where only from the surface, but today when i decided to take the rings off, two chunks came off, i was amazed that my block didnt get damaged.. Now i got a set of pistons coming, and rings, with an oem HG set, and the block is in good condition, so i should be up and running by the end of the week.. This shit is weird...im hella stumped... Edgar dont sell ur SR lets just re-build it!!!! | |
| Subject: Re: Blood Diamonds.... Part 1. January 19th 2009, 6:32 pm | |
- Edgar dont sell ur SR lets just re-build it!!!!
this! rebuilt SR's all around the squad. make it happen. no part outs. | |
| Subject: Re: Blood Diamonds.... Part 1. January 19th 2009, 6:50 pm | |
| nice man! im surprised you didnt opt for a cometic HG instead since your only going to do it once. | |
| Subject: Re: Blood Diamonds.... Part 1. January 20th 2009, 7:34 am | |
this! rebuilt SR's all around the squad. make it happen. no part outs. Maybe. | |
| Subject: Re: Blood Diamonds.... Part 1. January 20th 2009, 3:53 pm | |
| yea why not just get a cometic gasket from TF..?
oem is so thin. | |
SIMON Post Whore
| Subject: Re: Blood Diamonds.... Part 1. January 20th 2009, 4:56 pm | |
| dayum. glad to hear your block isnt ruined man. | |
| Subject: Re: Blood Diamonds.... Part 1. January 20th 2009, 6:16 pm | |
this! rebuilt SR's all around the squad. make it happen. no part outs. Maybe. no maybes. only yeses. im gonna go post some pics to inspire you now. but not in trucky's thread. | |
| Subject: Re: Blood Diamonds.... Part 1. January 20th 2009, 6:28 pm | |
- yea why not just get a cometic gasket from TF..?
oem is so thin. i would go with oem over cometic too.. cometic is garbage... | |
| Subject: Re: Blood Diamonds.... Part 1. January 21st 2009, 2:25 pm | |
| - LongGrain wrote:
- i would go with oem over cometic too.. cometic is garbage...
Cometic is fine, they do great stuff. As long as you get the correct one. Getting 88mm bore one from a retailer cuz thats what they had in stock = | |
| Subject: Re: Blood Diamonds.... Part 1. January 21st 2009, 4:46 pm | |
oem is so thin. i would go with oem over cometic too.. cometic is garbage... i've been running one for a little over 6months with not 1 single problem @ 14psi. | |
SPEEDTRIBE Post Enthusiast
| Subject: Re: Blood Diamonds.... Part 1. January 21st 2009, 5:57 pm | |
oem is so thin. i would go with oem over cometic too.. cometic is garbage... is this serious?? | |
| Subject: Re: Blood Diamonds.... Part 1. January 21st 2009, 6:14 pm | |
| I read up on cometic, and i did want one but im kinda pressed for money..so thats why i didnt... | |
| Subject: Re: Blood Diamonds.... Part 1. January 21st 2009, 6:40 pm | |
| Allright this gonna sound kinda like a newb question, but how do i know wich one to get, since they got like 5 different choices... This kinda crap stumps me... Since my shit is just stock...pretty much... I think it would be 86.0mm x 0.045", or would it be 86.5mm x 0.040" | |
| Subject: Re: Blood Diamonds.... Part 1. | |
