 where does the green wire go
where does the green wire go Empty
PostSubject: where does the green wire go   where does the green wire go Icon_minitimeSeptember 20th 2007, 4:26 pm
my stock tach doesnt work so im hooking up an autometer tach on my s14sr with the wc ecu.i tried to hook the green wire to the tach signal output and its not working.if it doesnt work there then what should i hook the green wire to.i searched but i found no answers
PostSubject: Re: where does the green wire go   where does the green wire go Icon_minitimeSeptember 20th 2007, 7:01 pm
I hooked mine up to the Light green/black wire on my distributor... I think
SEXYDRIFTER
SEXYDRIFTER
Number of posts : 247
Vehicle : 1990 nissan 240sx se hb rps13
PostSubject: Re: where does the green wire go   where does the green wire go Icon_minitimeSeptember 21st 2007, 1:27 am
r u sure cuz i found no answers and my tach is going out so i bought a faze tach gauge so i am hoping looking foward to it ill see what can i do
Number of posts : 2227
PostSubject: Re: where does the green wire go   where does the green wire go Icon_minitimeSeptember 21st 2007, 11:27 am
ka and sr are different. ka - distributor, sr - coil pack. i've never installed a tach on a sr, but usually you can do 1 of 3 things. either connect directly to the ecu tach wire (sometimes you get lucky and it works). connect to wire behind the gauge cluster (again luck). or you need to buy a tach adapter (autometer makes one, MOST COMMON WAY), so it reads the signal accurately. keep in mind every car is different.
PostSubject: Re: where does the green wire go   where does the green wire go Icon_minitimeSeptember 21st 2007, 3:47 pm
i figured it out cause im a ninja
PostSubject: Re: where does the green wire go   where does the green wire go Icon_minitimeSeptember 21st 2007, 4:39 pm
rock on NINJA
» Wtb: wire harness
» kade wire set
» looking for some one that can do a wire tuck
» WTB: wire tuck help
» do it..do it...green
