| Need Sr20det starter ASAP!!!!!!!!!! | |
Mr.BackFire Established Member
Number of posts : 555 Age : 37 Location : Illinoi Vehicle : 240sx se Reputation : 0
| Subject: Need Sr20det starter ASAP!!!!!!!!!! September 1st 2007, 4:09 am | |
| mine crapped out on me, and i need one like right now! So if you got one let me know, thanks. | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 1st 2007, 1:07 pm | |
| im pretty sure Enjuku sells refurbished starters | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 1st 2007, 5:43 pm | |
| for how much tho, i dont exactly have a big budget to spend (broke:( | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 2nd 2007, 10:02 am | |
| I heard that the sentra (sr20de) starter will fit. I'll let you know. Mine went out also about a month ago : ( | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 3rd 2007, 7:48 pm | |
| yeah man that sucks, at least you have a daily, i'm screwed lol. yeah find out about the sr20de, the end of the starter has to be inside though, because it comes out unlike the ka which sticks out, i'm sure u know tho, thanks man. | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 5:13 pm | |
| No longer need this. I'm buying of a guy from 240sxforums, and the sr20de starter isn't compatible, it looks more like a ka starter. | |
lopez6558 Forum Frequenter
Number of posts : 321 Age : 36 Location : Schuamburg IL Vehicle : 95 240sx coupe/96 240sx coupe Reputation : 0
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 5:28 pm | |
| ka starters will work with the sr though. | |
Guest Guest
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 9:21 pm | |
| - lopez6558 wrote:
- ka starters will work with the sr though.
no it wont |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 9:30 pm | |
| yea i helped my cuz with his sr and we used the stock ka starter, it wasn't a direct bolt on though. some guy at touge factory explaind to us how to use the ka starter. | |
Guest Guest
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 10:05 pm | |
| - lopez6558 wrote:
- yea i helped my cuz with his sr and we used the stock ka starter, it wasn't a direct bolt on though. some guy at touge factory explaind to us how to use the ka starter.
well share the story many people here on the forum would greatly apperciate the info and will help save alot of money |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 7th 2007, 10:19 pm | |
| - red7 wrote:
well share the story many people here on the forum would greatly apperciate the info and will help save alot of money for sure. if you're going to tell us that the KA starter works, please take the time to explain how it does and what needs to be done to make it work. | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 11th 2007, 7:59 pm | |
| It's actualy very easy and cheap . Take out your sr starter, then get aka starter. If you only need the solenoid then just take that off it's a direct fit. If you need the actual coil part, then un bolt the two long thin bolts at the end of each starter, then it's all just memory from there. Rightnow i have a ka coil with the sr gear... nice. | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 12th 2007, 8:19 pm | |
| Well I finally got mine rebuilt.
Grrrr....cost me $120.
Which ain't tooo bad.... | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 14th 2007, 5:56 am | |
| WHaaaaa! dam if i only got to you sooner, you could have gotten yours workin in no time, and for 15 bucks, unless you had a ka starter lyin around, o well at least it's all new now. | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! September 14th 2007, 9:29 am | |
| Subject: Re: Need Sr20det starter ASAP!!!!!!!!!! | |
